Tractorman Posted July 30, 2013 Share Posted July 30, 2013 Hi All, need to do a cambelt on my 300tdi, its long overdue... whats the feeling on cambelt kits - my local dealer is doing full kits, Dayco belt but its Britpart pulleys and not cheap, The Glencoyne kit looks good but he claims "only good quality components" but doesn't say what, or whos they are. - any preferred kits? any to avoid? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 31, 2013 Share Posted July 31, 2013 Used to get ours from Bearmach Quote Link to comment Share on other sites More sharing options...
cackshifter Posted July 31, 2013 Share Posted July 31, 2013 I've had a couple of Bearmach ones with no problems. The crank pulley they do was a solid one rather than with welded on flanges, to be honest, looked a better item. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 31, 2013 Share Posted July 31, 2013 Would agree the solid crank pulley on the bearmach kit seems better, heard a few stories of the spot welded flanges on the genuine one failing. Quote Link to comment Share on other sites More sharing options...
Tractorman Posted July 31, 2013 Author Share Posted July 31, 2013 is it usual to replace the bottom pulley? its not included in a lot of kits. I know the tensioners are changed as they contain bearings but why the bottom pulley? Does it wear quicker than the others? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 31, 2013 Share Posted July 31, 2013 The standard bottom pulley has welded on flanges which fail as described above. Changing it is a sensible precaution; changing it for a solid Bearmach one is a much better precaution! Quote Link to comment Share on other sites More sharing options...
cackshifter Posted August 1, 2013 Share Posted August 1, 2013 If you do change the bottom pulley, I'd do the oil seal behind. The pulley is a right PITA to get off and the seal is cheap so you might as well. There is also a big O ring that goes behind the pulley that 'stops' oil seeping along the pulley/crank gap. Quote Link to comment Share on other sites More sharing options...
Confused Posted August 6, 2013 Share Posted August 6, 2013 Can anyone suggest where the best place to buy the bearmach equipment via mail order might be? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 7, 2013 Share Posted August 7, 2013 We used to deal with the south-east shop who were excellent, very very helpful. Changed jobs 2 years ago and no dealings since. Not sure if they do mail order within the UK but worth asking? http://www.callupcontact.com/b/business/Bearmach_South_East/916089 Quote Link to comment Share on other sites More sharing options...
Confused Posted August 12, 2013 Share Posted August 12, 2013 We used to deal with the south-east shop who were excellent, very very helpful. Changed jobs 2 years ago and no dealings since. Not sure if they do mail order within the UK but worth asking? http://www.callupcontact.com/b/business/Bearmach_South_East/916089 Thanks for that, I gave them a call and they do do mail order, its £10+vat and they wanted £94+vat for the kit which works out around £125 delivered. I used their website to find a local distributer though and realised the place I buy most of my parts is a Bearmach distributer. They (MPB Keighley) have got the same kit on ebay (solid crank pulley and dayco belt) for £87 delivered which is a bit easier on the pocket. Thanks for the pointer, it got me where I wanted in the end! Quote Link to comment Share on other sites More sharing options...
cackshifter Posted August 14, 2013 Share Posted August 14, 2013 Mailorder4x4 are a Bearmach tentacle I believe, so should have access to their stuff if you cannot get it there. I have used them a bit and had no problems, in fact they have been very helpful. Quote Link to comment Share on other sites More sharing options...
