Tom17 Posted August 12, 2013 Share Posted August 12, 2013 This has happened twice now in a year only had that car a year but surly this should be happening so frequently is this just bad luck both cables were brand new on Quote Link to comment Share on other sites More sharing options...
Tanuki Posted August 12, 2013 Share Posted August 12, 2013 Check the engine-to-chassis earths! If the earth goes high-resistance the starter-motor current will find its way from the block to the chassis by the next available path. If this is the throttle-cable it heats up and the nylon inner lining melts, causing the cable to stick/bind. If you're really unlucky they can glow red-hot. Quote Link to comment Share on other sites More sharing options...
Maverik Posted August 12, 2013 Share Posted August 12, 2013 What vehicle do you have? age? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 12, 2013 Share Posted August 12, 2013 Have you checked it's not the pedal sticking? The limit screw on my pedal was catching on the footwell mat. Quote Link to comment Share on other sites More sharing options...
Tom17 Posted August 12, 2013 Author Share Posted August 12, 2013 Have you checked it's not the pedal sticking? The limit screw on my pedal was catching on the footwell mat. No not the pedal can see the cable sticking! It's a 1984 90 with a 200tdi defender engine fitted Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 12, 2013 Share Posted August 12, 2013 Ah thats OK then. Same set-up as me then Quote Link to comment Share on other sites More sharing options...
mmgemini Posted August 12, 2013 Share Posted August 12, 2013 Is the inner cable fraying inside the outer ? Quote Link to comment Share on other sites More sharing options...
jbs Posted August 12, 2013 Share Posted August 12, 2013 I would still check at a stand still with the engine off to see if the pedal sticks to the floor mat as I've had this once or twice in my 15+ years of owning land rovers The floor mat moves forward allowing the pedal to be trapped when you floor it as the mat gets kinked up at the bulkhead end of the footwell John Quote Link to comment Share on other sites More sharing options...
Maverik Posted August 12, 2013 Share Posted August 12, 2013 I would still check at a stand still with the engine off to see if the pedal sticks to the floor mat as I've had this once or twice in my 15+ years of owning land roversThe floor mat moves forward allowing the pedal to be trapped when you floor it as the mat gets kinked up at the bulkhead end of the footwell John Something similar to John's post but the pedals do have an internal return spring in the pedal assembly too from memory, how "healthy" is the spring? Quote Link to comment Share on other sites More sharing options...
western Posted August 12, 2013 Share Posted August 12, 2013 lubricate the throttle lever on the injection pump,it should be free to move. Quote Link to comment Share on other sites More sharing options...
