Defender throttle cable stuck on
Check the engine-to-chassis earths! If the earth goes high-resistance the starter-motor current will find its way from the block to the chassis by the next available path. If this is the throttle-cable it heats up and the nylon inner lining melts, causing the cable to stick/bind.
If you're really unlucky they can glow red-hot.
I would still check at a stand still with the engine off to see if the pedal sticks to the floor mat as I've had this once or twice in my 15+ years of owning land rovers
The floor mat moves forward allowing the pedal to be trapped when you floor it as the mat gets kinked up at the bulkhead end of the footwell
John
John
Something similar to John's post but the pedals do have an internal return spring in the pedal assembly too from memory, how "healthy" is the spring?
