Front propshaft: double cardon vs UJ
o_teunico
Hi all
A friend is experiencing too much play in the front prophaft of his Disco 300. Vehicle is lifted 3" with QT castor correcting radious arms and the Paddock sourced doublé cardon prop has come to the end of it´s life (it was non greaseable type).
We like the one that Bailey Morris makes for Gwyn Lewis, but it´s over budget. Will a phased single UJ 30º prop perform OK in this aplication? Single UJ type is less than half of the Price of the doublé cardon type.
A double carden joint takes out the fast slow motion caused by the elliptical rotation of a UJ... this is normally not an issue unless your drive shaft is at a good amount of angle... at 3" of lift I'd run a single UJ
I have to use single UJ drive shafts with some of the young lads trucks as they seem to think tall is good.... it does wear out the UJ faster and in theory wear out your tyres and drive line due to the pulsing, but I've yet to see indications of this... wear from the offroad use is way worse
I would suggest you get your drive shaft balanced since your going to be lengthing it
  • 5 weeks later...
  • 2 weeks later...
The prop has been tested. Everything seems OK. There is a mínimum vibration when using engine braking, but it will be difficult to say if it´s because of the prop, as this vehicle is running some 33" remoulds and has suffered "death wobble" in the past.
