Paddy Posted January 5, 2014 Share Posted January 5, 2014 1991 2.5 nad, used to stop as soon as the ignition key turned to off. Its now hesitating for a second or so before the engine stops. I’m looking at replacing the fuel cut off solenoid BAU4611L but Jeezus what a difference in price. Brit, allmake, bearmach at around £10 and then a genuine LR one at £130 ! I’m all for using genuine bits but that is some difference. Found Craddock selling a Delphi BAU4611LG for £32 which is a bit more like it. Any advice or preferences ? Quote Link to comment Share on other sites More sharing options...
landrover620 Posted January 5, 2014 Share Posted January 5, 2014 I have had the same trouble with mine, I took it out and stretched the spring a bit then put it back and it worked fine. Stay clear of cheap ones I tried one and it was useless. Hope that helps Chris. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 5, 2014 Share Posted January 5, 2014 I've not had to buy one Paddy, but looking at prices and makes I would be inclined to go for the Delphi item. HTH Mo Quote Link to comment Share on other sites More sharing options...
Paddy Posted January 5, 2014 Author Share Posted January 5, 2014 I have had the same trouble with mine, I took it out and stretched the spring a bit then put it back and it worked fine. Stay clear of cheap ones I tried one and it was useless. Hope that helps Chris. Haven’t taken it out for a look yet, rather wet at the moment!! I’ll try your trick first and then go for the Delphi if needed, unless someone warns me off. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 5, 2014 Share Posted January 5, 2014 I'd also be inclined to go for the delphi at that price. However, I've had plenty of Bearmach branded stuff and its all been great, so I might go that route. Quote Link to comment Share on other sites More sharing options...
smallfry Posted January 5, 2014 Share Posted January 5, 2014 Paddy I have got a Brand new genuine Lucas CAV one you can have for £20 Their part number for it is 9009-049. I do not know how to add a photo of it to this forum, but if you send me a PM with your emaill address, I will send it to you Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted January 5, 2014 Share Posted January 5, 2014 I have used durite stop solenoids before. They are good quality and a reasonable price. Check at your local durite dealer to see if they can cross reference it. Quote Link to comment Share on other sites More sharing options...
smallfry Posted January 5, 2014 Share Posted January 5, 2014 I have used durite stop solenoids before. They are good quality and a reasonable price. Check at your local durite dealer to see if they can cross reference it. Yep. I have always found Durite stuff to be excellent quality. Its just a shame that they stopped doing most parts for alternators and starters a few years ago. Quote Link to comment Share on other sites More sharing options...
Paddy Posted January 6, 2014 Author Share Posted January 6, 2014 Paddy I have got a Brand new genuine Lucas CAV one you can have for £20 Their part number for it is 9009-049. I do not know how to add a photo of it to this forum, but if you send me a PM with your emaill address, I will send it to you Thanks, PM'd Quote Link to comment Share on other sites More sharing options...
smallfry Posted January 6, 2014 Share Posted January 6, 2014 Email sent.................... If anyone else wants one I have got a couple more ! Quote Link to comment Share on other sites More sharing options...
Paddy Posted January 19, 2014 Author Share Posted January 19, 2014 Problem solved with a new solenoid from Smallfry. While I could have stretched the spring, this way, with a new unit, it should it should last for another 20 years ! Quote Link to comment Share on other sites More sharing options...
