lol Posted June 29, 2014 Share Posted June 29, 2014 Just before I take it out could any one shed any light on what could be a possible problem? Went to engage my locker and air is hissing through the breather pipe and air locker is not engaging? Any one had this before? Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted June 29, 2014 Share Posted June 29, 2014 Yes, swapped to an Ashcroft locker Until then we tried thicker oil. New orings etc etc Quote Link to comment Share on other sites More sharing options...
lol Posted June 29, 2014 Author Share Posted June 29, 2014 Yes, swapped to an Ashcroft locker Until then we tried thicker oil. New orings etc etc Thanks for the reply So you never did get to the bottom of the problem? Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted June 29, 2014 Share Posted June 29, 2014 Depending on how long its been in there and whether it's a RD56 or RD128 then note the following: The RD128 (later model) has the copper pipe routed over the crown wheel teeth and so if this isn't correctly routed when originally fitted then the crown wheel can rub up against it and 'machine away' at it causing an air leak. The o-rings may have failed or got pinched as Mike suggests. Or depending on how it stopped working, then you may have damaged the actual diff? Steve Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 29, 2014 Share Posted June 29, 2014 O rings usually. Mo Quote Link to comment Share on other sites More sharing options...
lol Posted June 29, 2014 Author Share Posted June 29, 2014 Cheers for the advice chaps, It stopped working at an event had been using it then one hole flicked it in and compressor just runs and can hear air through the breather pipe Quote Link to comment Share on other sites More sharing options...
zim Posted June 30, 2014 Share Posted June 30, 2014 The o rings aren't the sole problem, sometimes the end cap the seal on also needs replacing. G Quote Link to comment Share on other sites More sharing options...
