kevin50 Posted August 17, 2014 Share Posted August 17, 2014 Decide to have a go and change door hinges.Got the first bottom hinge off, the two hinges that bolt into the pillar have went in OK, But the two bolts that go into the door will not go through long enough to get a nut on the other end.Bolts are Excactley the same size as the ones that came out.Dont know whats went wrong as everything lines up.????Looks like Im going to have to leave it till tomorrow, getting too dark now. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted August 17, 2014 Share Posted August 17, 2014 Have you got the hinges the right way around? They are tapered to match the angle at the top of the door skin Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 17, 2014 Author Share Posted August 17, 2014 It is just second hand hinges Im putting back on as the ones that are on are really knackered. I made sure the hinge I was putting back on was excactly the same way I took the old one off. It does match up perfectly flush with the door, one bolt comes through a couple of mill the other just say comes flush , I mpossible to get a nut on either. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted August 17, 2014 Share Posted August 17, 2014 Are your replacement hinges any thicker on the casting? Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted August 17, 2014 Share Posted August 17, 2014 check the taper on the new bolts compared to the taper in the bolt hole on the hinge. It may be different and not aloowing the bolt head to sit as deep in the hinge?? Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 17, 2014 Author Share Posted August 17, 2014 Are your replacement hinges any thicker on the casting? Both the same Mate, but top and bottom of each hinge are different shape. Maybe the are they Sided?? left and right? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 17, 2014 Share Posted August 17, 2014 They are sided ... That's what Scott meant when he said were they the right way around. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 17, 2014 Author Share Posted August 17, 2014 Is the Tapered edge on the top of the hinge, the bottom different shape and thicker. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 17, 2014 Share Posted August 17, 2014 From memory they are both tapered - with the thinner edge being the top edge - and with the bottom hinge being thicker than the top. So a full set is 4 different hinges - with each one fitting in only one place. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 17, 2014 Author Share Posted August 17, 2014 From memory they are both tapered - with the thinner edge being the top edge - and with the bottom hinge being thicker than the top. So a full set is 4 different hinges - with each one fitting in only one place. Thats the way I have thereplacment hinge fitted thinner edge top. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 17, 2014 Share Posted August 17, 2014 I may have said it wrong - the top ones may be thicker. Daft question - but you're not trying to fit a top hinge on the bottom are you ? The holes for the mirror should give it away. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 17, 2014 Author Share Posted August 17, 2014 I may have said it wrong - the top ones may be thicker. Daft question - but you're not trying to fit a top hinge on the bottom are you ? The holes for the mirror should give it away. No Mate I have the top ones with holes for mirrors separate. Im sure I fitted the replacment the excact same way as the old one was on. infact the other side has the thinner edge on top too. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted August 17, 2014 Share Posted August 17, 2014 Thinner edge to top is correct...has the skin popped open a bit and is now creating a gap between the skin and frame? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 17, 2014 Share Posted August 17, 2014 The bolts for the door side of the hinge are longer - you've not put the door bolts into the bulkhead by any chance ? Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 17, 2014 Author Share Posted August 17, 2014 The bolts for the door side of the hinge are longer - you've not put the door bolts into the bulkhead by any chance ? No Mate. I have the longer ones in. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 17, 2014 Author Share Posted August 17, 2014 Thinner edge to top is correct...has the skin popped open a bit and is now creating a gap between the skin and frame? Dont think so will have to have a good look around it tomorrow night after work. Got me Baffled as to why they dont fit. Quote Link to comment Share on other sites More sharing options...
steve b Posted August 18, 2014 Share Posted August 18, 2014 On the last set I fitted for someone the bolt head was too big to fit into the counterbore in the door section of the hinge , so I took some metal off the bolt head dia with a flap wheel cheers Steveb Quote Link to comment Share on other sites More sharing options...
kevin50 Posted August 18, 2014 Author Share Posted August 18, 2014 Gonna have another go tonight.Got some longer bolts incase I cant solve the problem. Quote Link to comment Share on other sites More sharing options...
