Davo Posted August 18, 2014 Share Posted August 18, 2014 I was just wondering if a front axle from a 1983 110" would go into a 1983 Range Rover. I happen to have both of these here, but the 110 is terminally rusty and the Rangie is our everyday 4WD. So I wouldn't mind the 110 axle with bigger brakes and more easily upgraded, (i.e., Ashcroft), CVs and stub axles and so on. I know that the brakes would need a little change in the pipework since it would be going from two lines to each caliper to one line each, the springs will fit, the steering should fit, diff is the same, (though I'll be putting in a Truetrac as in the rear), but are the radius arms the same and, a big question: is the track the same? I've got alloys on the Rangie I'm keeping so I was planning on replacing the 110 wheel studs with RYF500010 studs for alloys. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted August 18, 2014 Share Posted August 18, 2014 Early rangies used a smaller panhard rod bush with corresponding smaller hole in the chassis bracket. Not sure if early 110 may have used the same, a quick check of the parts book should show if they used the same bush. Quote Link to comment Share on other sites More sharing options...
Davo Posted August 18, 2014 Author Share Posted August 18, 2014 Thanks for that. That's one thing I'd forgotten about. Being a parts book nerd, I've got both books right here and no, bushes and bolts are different. Oh well, I've got a spare Rangie front end handy and I can always take that apart as well as the 110 for a comparison. (Mental note: must clear up personal junkyard anyway.) Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 18, 2014 Share Posted August 18, 2014 The 110 axle will have the stronger AEU2522 CVs, but other than that the axle is similar strength wise. Both are just as easy to upgrade with Ashcroft bits. Quote Link to comment Share on other sites More sharing options...
chris200100 Posted August 18, 2014 Share Posted August 18, 2014 Also a 1983 110 axle would have bigger hubs you wouldn't get you alloys on it. Quote Link to comment Share on other sites More sharing options...
Davo Posted August 19, 2014 Author Share Posted August 19, 2014 Yes, those are good points, thanks for that. Mostly I just want the bigger brakes. On aulro there are quite the discussions about that and the end result sounds like 110 front brakes are the best thing you can do with a RRC. What put me off was how the caliper holes don't quite line up, (or are bigger, I think), and people had the bolts come loose. Nobody really seemed to have a better way to do it. What's this about hub size? Is this the centre of the hub where the drive flange bolts onto? That'll be another thing to measure . . . Quote Link to comment Share on other sites More sharing options...
