subseauk Posted December 12, 2014 Share Posted December 12, 2014 Hi I have a rattling type of sound that seems to come from the front of the 90 when i go above 40mph and then either press in the clutch or take my foot of the accelerator. The 90 has been taken into a landy garage and the usual suspect was the UJs and even one propshaft was changed when a UJ circlip was found not to be fitted correctly and the cost of the yoke was similar to a replacement Propshaft. Unfortunately this still did not cure the problem. The garage also said there was a slight play in the transfer box flanges and rear differential pinion flange but nothing significant!! They also suggested that the 2" lift on the 90 could be the culprit but this was already done before i bought it and it never happened before. The only other thing that another friend suggested might have something to do with the two new axles that were fitted complete with ARB diff locks but these have yet to be used in anger as the truck was already laid up when they were fitted. The garage just plumbed the compressor and air lines to the diffs. Any ideas as to the probable cause of this noise or the best way to isolate things as the garage seems to be stumped or too busy to look further!! Cheers Kev Quote Link to comment Share on other sites More sharing options...
Tanuki Posted December 12, 2014 Share Posted December 12, 2014 What age? What engine? I'd first be looking at propshaft UJs and the constant-velocity-joints in the swivel-hubs. Return the vehicle to standard-spec and see if you still have problems?? My stock 90TD5 can happily go hunting BMWs at 85-90MPH without any transmission- or steering-shudder issues. 1 Quote Link to comment Share on other sites More sharing options...
eds Posted December 12, 2014 Share Posted December 12, 2014 If the rattle is really rattley, I had a similar thing with the mud guards rattling on the diff input bearings. They rattled when they could. Quote Link to comment Share on other sites More sharing options...
subseauk Posted December 12, 2014 Author Share Posted December 12, 2014 Hi Guys eds what do you mean "mud guards rattling on the diff input bearings" ? where are these guards? appologies if i'm being dense but i've had a long day :-) Tanuki, the vehicle is about '93 Q Plate, 2" lift, discovery 200tdi transplant and converted to a pickup with open back tub. However, the only changes since the noise started have been new front & rear axles with ARB diff locks, new rear tub, new wings and a new seat box. the 2" lift etc was already in place and the rest has been checked over by the garage prior to its recent MOT. Oh also had a completely new electric loom front to rear. As stated the UJs have been changed as has one of the prop shafts but still the same when clutching or taking the foot off the accelerator above 40mph Not really practical to go back to a "standard" vehicle so any other thoughts? Quote Link to comment Share on other sites More sharing options...
stuck Posted December 12, 2014 Share Posted December 12, 2014 Take the front prop shaft off & go for a drive. Quote Link to comment Share on other sites More sharing options...
eds Posted December 13, 2014 Share Posted December 13, 2014 Having read your description again I think I am wrong as my rattle was not so deep. The flange mud guards cap the diff input seals. http://www.lrseries.com/shop/product/listing/174/236072-MUDSHIELD-FOR-DIFF-FLANGE.html Quote Link to comment Share on other sites More sharing options...
subseauk Posted December 13, 2014 Author Share Posted December 13, 2014 Test drive with Propshafts disconnected due it think ? Quote Link to comment Share on other sites More sharing options...
Paddy Posted December 17, 2014 Share Posted December 17, 2014 Spookily my 90 has started doing the same ‘sound’, except mine it’s when the engine/gearbox strains a bit when in too higher gear. Drop down to a lower gear and all is well. Did you get anywhere with your investigations subseauk ? Any info might shorten my fault finding. Quote Link to comment Share on other sites More sharing options...
subseauk Posted January 7, 2015 Author Share Posted January 7, 2015 Spookily my 90 has started doing the same ‘sound’, except mine it’s when the engine/gearbox strains a bit when in too higher gear. Drop down to a lower gear and all is well. Did you get anywhere with your investigations subseauk ? Any info might shorten my fault finding. Hi Paddy, Sorry havent had a minute to do any further investigations due to other commitments. I will update as soon as any progress is made. Thanks Quote Link to comment Share on other sites More sharing options...
Paddy Posted January 8, 2015 Share Posted January 8, 2015 Cheeky I know, but hoping to let you do the hard work, then cribbing off you !!Its cold, wet and miserable here and I just don’t fancy dropping bits off to investigate yet. I can live with mine by driving to avoid it, so I look forward to your update or vice versa if/when the weather picks up. Quote Link to comment Share on other sites More sharing options...
discomikey Posted January 8, 2015 Share Posted January 8, 2015 paddy sounds to me like the exhaust mauy be rattling or an engine/gearbox mount may have collapsed or gone hard. check the engin3 bay and drive train for anything loose. deep vibrations under power can also be knackered uj's and you will feel this through the whole truck not just the steering etc Quote Link to comment Share on other sites More sharing options...
Paddy Posted January 9, 2015 Share Posted January 9, 2015 The truck is a 1991 90 2.5 na, I replaced a seized prop and replaced all UJ’s, all fine a few months ago when re-greased. Exhaust seems fine with no chafing, considering its age the ‘mounts’ could be the place to start, thanks. I’m a softie, so I will be waiting for the weather to pick up before I start dropping props off, heaving on things for looseness etc. Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted January 9, 2015 Share Posted January 9, 2015 Just as an aside..............I stayed in Texas for a spell and once my neighbours complained of something rattling under the bonnet. Took a look and found a large rattlesnake curled up in the engine bay where it had been attracted by the warmth the previous evening! Quote Link to comment Share on other sites More sharing options...
need4speed Posted January 9, 2015 Share Posted January 9, 2015 No way would you hear a rattlesnake under the bonnet of a defner... Quote Link to comment Share on other sites More sharing options...
Paddy Posted January 10, 2015 Share Posted January 10, 2015 Just as an aside..............I stayed in Texas for a spell and once my neighbours complained of something rattling under the bonnet. Took a look and found a large rattlesnake curled up in the engine bay where it had been attracted by the warmth the previous evening! Thanks to Patrick it won’t be a problem here, Quote Link to comment Share on other sites More sharing options...
