JST Posted November 3, 2006 Share Posted November 3, 2006 get the thing out of the axle mounting?. tried a ball joint splitter, not in complete anger yet as dont want to trash the rubber seal. never had a problem getting them out of the axle locating hole before. also tried hitting it from below and pring the A frame, any other ideas? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted November 3, 2006 Share Posted November 3, 2006 Try twatting the side of the tapered hole, ie. from the rear of the axle, while prying at the same time. This deforms the hole and forces the taper out. Chris Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 3, 2006 Share Posted November 3, 2006 Usually belting the ball joint housing pops it out. Must be damned tight if it won't budge. Try leaving the nut undone a small amount and go for a drive. Les. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted November 3, 2006 Share Posted November 3, 2006 Try jacking the nose of the diff a little. Whilst doing this jack the a frame. Then thump the housing - worked for me . Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted November 3, 2006 Share Posted November 3, 2006 Try jacking the nose of the diff a little. Whilst doing this jack the a frame. Then thump the housing - worked for me . Yes it probably won't let go if its still under load. jack nose of diff untill you find a neutrally loaded position. Bill. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted November 3, 2006 Share Posted November 3, 2006 Took a very big hammer and a lot of anger therapy to get mine to let go. HIT IT................ it will give! Quote Link to comment Share on other sites More sharing options...
JST Posted November 3, 2006 Author Share Posted November 3, 2006 so hit it, and hit it hard, but which bit, axle mounting, top of A frame or whole lot repeatdly? and jack diff nose (which is low as prop is off) Quote Link to comment Share on other sites More sharing options...
Lewis Posted November 3, 2006 Share Posted November 3, 2006 When we changed my rear axle i had a mate stand on the axle on either side of the ball-joint while i beat the axle where the taper mounts repeatedly with a large sledge hammer. Worked nicely on both the disco and the 90 This only works if you havnt got a tub fitted Lewis Coat, hat, door swinging in the breeze Quote Link to comment Share on other sites More sharing options...
white90 Posted November 3, 2006 Share Posted November 3, 2006 put some pressure on the A frame with a trolley jack then hit the axle mount. Quote Link to comment Share on other sites More sharing options...
