defender dinky Posted May 14, 2015 Share Posted May 14, 2015 hi,i am about to put a new bottom arm on my adwest steering box at the mo its a discovery one I'm changing it to a defender setup with a built in balljoint now at the back of steering arm there seems to be a slot and on the box itself theres a hole is this how you line them up by putting a pin through then remove the pin, dd Quote Link to comment Share on other sites More sharing options...
western Posted May 14, 2015 Share Posted May 14, 2015 That's for centralising the box, search on here for that info, I've posted it a while ago Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 14, 2015 Share Posted May 14, 2015 Also - I'd seriously consider sticking with the discovery arm. Those built in ball joints can be hideous to change.... 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 14, 2015 Share Posted May 14, 2015 Another vote for the disco drop arm. Its FAR easier to change one of those than the silly defender type in the future! Quote Link to comment Share on other sites More sharing options...
defender dinky Posted May 14, 2015 Author Share Posted May 14, 2015 putting steering box on my defender 110 rebuild draglink has a swan neck fitting for steering arm and so I can fit damper,dd Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 14, 2015 Share Posted May 14, 2015 You can get kits to fit the damper with a Disco arm..... Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 14, 2015 Share Posted May 14, 2015 Using the disco drag link, you then use a clamp on damper mount. I didn't bother with the damper at all and my steering was lovely. Quote Link to comment Share on other sites More sharing options...
Monster Posted May 15, 2015 Share Posted May 15, 2015 I'll have the discovery drop arm if you dont want it! Quote Link to comment Share on other sites More sharing options...
