jamesledingham Posted November 12, 2006 Share Posted November 12, 2006 My 1990 Pickup cab only has the 1990 factorty fitted radio in it...no aerial, and only a built in speaker. I'm either lookng at one of these http://www.mobilestoragesystems.fsnet.co.uk/store-caddy.htm Which would make sense as I'm after a locking cubby box anyway. The other option (Which would presumably be easier to wire) is http://www.mudstuff.co.uk/Dashconsole.html Which has the added advantage of blanked plates for switches (if and when I start putting extras in!) TWO QUSTIONS REALLY: Is the wiring that provides power to the current radio going to be enough to be enough to power a modern day radio/cd? Where on earth would you put speakers in a truck cab? I have 2 6x9s from a previous car which I'd like to use if possible. Quote Link to comment Share on other sites More sharing options...
LR90 Posted November 12, 2006 Share Posted November 12, 2006 Welcome I'm sure the existing supply will be adequate and the consoles seem very popular (do a quick search or look in the Int forum for members comments/pics) Re speakers I think factory fit is under the dash either side and someone can probably provide part numbers or you could cut our your existing dash and fit. Another option is stick them in the door panels. I should add I have no radio in my 90 so this may not be the most qualified replay you'll get Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted November 12, 2006 Share Posted November 12, 2006 The following thread should help with the dash modification... http://forums.lr4x4.com/index.php?showtopic=6782 Power cables all there and should be all you need. I have a rubber aerial mounted at the rear of my 110 with cable threaded from rear... Have fun... Quote Link to comment Share on other sites More sharing options...
western Posted November 12, 2006 Share Posted November 12, 2006 The wiring is more than upto the job, so no probs there, speakers can be fitted in the standard end of dash locations as per most hardtop/station wagons or in your headlining inboard of where the top of your head will be when sat in the vehicle. Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted November 13, 2006 Share Posted November 13, 2006 I bought the fully loaded version of the centre console from Mobile Storage Systems with all the whistles and bells and it's really very smart and sooooo much better (but mooooooore expensive) than the standard effort. Quote Link to comment Share on other sites More sharing options...
jamesledingham Posted November 13, 2006 Author Share Posted November 13, 2006 I bought the fully loaded version of the centre console from Mobile Storage Systems with all the whistles and bells and it's really very smart and sooooo much better (but mooooooore expensive) than the standard effort. How much was it? There are no prices on the site and they've not replied to my e-mail yet! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 14, 2006 Share Posted November 14, 2006 bought the fully loaded version of the centre console from Mobile Storage Systems with all the whistles and bells and it's really very smart and sooooo much better (but mooooooore expensive) than the standard effort. If the cd player is mounted vertically in cubby box, does it still play the cds ? The reason I ask is because both of the cd players I've had in my landy both said in the instructions that the unit should be mounted within a certain degrees (30 IIRC) from horizontal. Just a thought. Mo Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 14, 2006 Share Posted November 14, 2006 I've seen a few CD players now where there is a small "screwdriver slot" type thing on the side of the case, which you rotate depending on if you're mounting it horizontally or vertically. Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted November 14, 2006 Share Posted November 14, 2006 The cubby box cost about £200 + VAT as I recall but unfortuately the receipt is at the accountants at present so cannot confirm. I have a fairly basic model JVC CD player from Half-wits and it plays pefectly well. Althogh the cubby box is expensive it is a very well-made and sturdy piece of kit and the arm rest is nice and thick and very comfy indeed. The fully loaded model comes with twin cup holders and insulated cups, trinket tray, cargo nets on both sides and twin auxiliary ciggy lighter sockets on the rear. I found the mounting instructions a bit lacking in detail (a comment which I passed on to the company) but in the end I threw them away and went with common sense!. There is large bracket which bolts across the underside of the centre seat box plate to prevent the whole box being wrenched out with the base plate. This has a tendency to rattle where it touches the metal flanges of the seat box but easy to resolve with bits of rubber packing and tape! Quote Link to comment Share on other sites More sharing options...
