molly Posted July 23, 2015 Share Posted July 23, 2015 A good friend has a really nice 2a petrol had the head converted to unleaded fitted with new carb now has a problem with setting mixture engine is hunting choke control does nothing only cuts out engine and engine seems to run better with volume control screw removed any help would be great thanks Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 23, 2015 Share Posted July 23, 2015 Sounds like the carb is leaking fuel from warpage, very common and no good ones available now.... if you aren't a stickler for originality and can wave a welder around you could fit an SU and having running wonderfully. Quote Link to comment Share on other sites More sharing options...
steve b Posted July 23, 2015 Share Posted July 23, 2015 What sort of new carb? It sounds like it may have a fault with the fuel level , so float/ needle valve or seat cheers Steveb Quote Link to comment Share on other sites More sharing options...
molly Posted July 23, 2015 Author Share Posted July 23, 2015 Hi thanks for the info ill check for the flange is flat and gas tight the carb is the standard zenith Quote Link to comment Share on other sites More sharing options...
Josh NZ Posted July 23, 2015 Share Posted July 23, 2015 Spray wd40 in/around the air intake joints and if it revs up you have an air leak somewhere Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 24, 2015 Share Posted July 24, 2015 Check the advance diaphragm, they can go religious and let fuel through. G. Quote Link to comment Share on other sites More sharing options...
tacr2man Posted July 24, 2015 Share Posted July 24, 2015 As previous poster suggested best solution is an SU , better mpg, and response , The carbs fitted to landrover series never were much bottle, although some were slightly better than others. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted July 28, 2015 Share Posted July 28, 2015 Sounds like the carb is leaking fuel from warpage, very common and no good ones available now.... if you aren't a stickler for originality and can wave a welder around you could fit an SU and having running wonderfully.An Su carb and Lumenition completely transform 2 1/4 LR engines,how the factory should have made them... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 28, 2015 Share Posted July 28, 2015 Yup, I have both, and sooooo smooth and torquey, and more top end as well. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted July 29, 2015 Share Posted July 29, 2015 Yup, I have both, and sooooo smooth and torquey, and more top end as well.Don't, you are reminding me how nice mine was,I'm wishing I hadn't bothered fitting my new build one with a 200TDI... Quote Link to comment Share on other sites More sharing options...
molly Posted August 5, 2015 Author Share Posted August 5, 2015 Hi thanks a lot for all the info the 2a is now sorted it was a carb problem this is the third new carb the Landys had sorted by a Landrover place in Blackburn Lancs that said they supplied the duff ones in the first place thanks again molly Quote Link to comment Share on other sites More sharing options...
