landroversforever Posted November 16, 2015 Share Posted November 16, 2015 What is the current thinking on tyre valve protection at the moment then? All the threads are from a while ago and new ideas might have come along since then! Either a U or V shaped bit of bent bar over it, or a piece of tube welded over it were the options I'd come across. Any fresh ideas out there? Cheers. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 16, 2015 Author Share Posted November 16, 2015 A variation on the tube type: http://www.syncmakina.com/uploadfile/20130615214128925.jpg Quote Link to comment Share on other sites More sharing options...
zardos Posted November 16, 2015 Share Posted November 16, 2015 Tube with plastic bung to stop dirt and stuff filling it up, plus it stops twigs still attacking it. From Artoffroad (https://artoffroad.wordpress.com/) 2 Quote Link to comment Share on other sites More sharing options...
Lewis Posted November 16, 2015 Share Posted November 16, 2015 I fitted shorter valves intended for go kart applications. They haven't got any protection but seem to cope fine with the use I give them If you have to have something Zardos' suggestion is the best I've seen Quote Link to comment Share on other sites More sharing options...
zardos Posted November 16, 2015 Share Posted November 16, 2015 I have also seen just metal valves used or you can get flush mount valves(some options)http://www.mistertee.co.uk/10.html Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 16, 2015 Author Share Posted November 16, 2015 I had the really short valves in there before I stripped the tyres off, so I will be using them again. I like the idea of the plastic bungs in the tubes if I go that route. I could always just leave it for now and just carry some spare valves? Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted November 16, 2015 Share Posted November 16, 2015 Beadlocks do a darn good job of preventing anything get at the valve... has anyone ever fitted them to the inside of the rim and use the bent extensions like used on dueler truck wheels or is there just not enough space around the brakes to get it all in? Quote Link to comment Share on other sites More sharing options...
zardos Posted November 16, 2015 Share Posted November 16, 2015 My double beadlock wheels do nothing to prevent things getting to the valve, hence a tube and bung.(you probably meant Beadlock rings, which is only one method of bead locking) Quote Link to comment Share on other sites More sharing options...
Daan Posted November 16, 2015 Share Posted November 16, 2015 If you run inner tubes, the tube around the valve is a complete PITA, because when you pump it up, you need to hold onto the valve with 2 fingers to stop the valve disappearing in the hole. Loops for me for this reason. Daan Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted November 16, 2015 Share Posted November 16, 2015 Yes apologies I meant the weld on bead lock ring which makes inflating the tyre a challenge Quote Link to comment Share on other sites More sharing options...
