Advice on which brakes for my 90 v8
When I bought my 90 many moons ago it had been fitted with RRC axles, servo and dual circuit brake callipers. Now these stop the car pretty well, but recently I have bought another much cleaner bulkhead from a TD5 which has the brake servo still attached, most of the brake lines and valve thing for rear axle.
I was wondering if I should ditch the RRC dual circuit and convert to the TD5 set up? I've got new axles to go on and was going to treat myself to new front callipers, so could easily buy TD5 ones instead.
Ok, that's interesting to know. My existing callipers have two brakes lines in each side on the front. Is there any advantage over this or the proper defender single line system. I'm sure safety is covered somewhere else in the single line system.
