cornflakes52 Posted April 19, 2016 Share Posted April 19, 2016 300tdi auto I have had a non working diff lock light for some time now and have finally gotten around to looking at it, the diff lock itself has been working fine though. So I checked the light and that was fine so I went to adjust the switch to see if that would do anything. Giving it a small twist and it sheared right off. Now I'm stuck with half a switch... Given that the switch is hollow I'm a little concerned about losing the transfer box fluid through the hole when running, guess I'll have to run it and see. But has anyone got any ideas about removing what's left of the switch? Cheers Quote Link to comment Share on other sites More sharing options...
Boydie Posted April 22, 2016 Share Posted April 22, 2016 Just use an "easy-out", otherwise known as stud or bolt extractors. They come in sets normally with matching drills for each size of extractor. They have helical left hand thread so when you "unscrew" the easy-out it screws into the remains of the switch and will screw it out of the box. Quote Link to comment Share on other sites More sharing options...
cornflakes52 Posted April 22, 2016 Author Share Posted April 22, 2016 Ahh fantastic, looks bang on what I need. Cheers mate Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted April 22, 2016 Share Posted April 22, 2016 As the man says, or as it's brass, gently unscrew it using a drift Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 22, 2016 Share Posted April 22, 2016 Tap a blade screwdriver in gently, just enough to get purchase, and twist out As above, it is brass, so pretty soft, also the reason it snapped off in the first place! Quote Link to comment Share on other sites More sharing options...
JeffR Posted April 22, 2016 Share Posted April 22, 2016 If you don't have a stud extractor kit, a suitable Torx bit works! BUT be careful. Quote Link to comment Share on other sites More sharing options...
Boydie Posted April 23, 2016 Share Posted April 23, 2016 Buy a set of easy-out extractors, they aren't expensive and will always come in handy with any Land Rover maintenance Quote Link to comment Share on other sites More sharing options...
qwakers Posted April 24, 2016 Share Posted April 24, 2016 id edit that and say buy a set of DECENT easy out extractors. a lot of the cheap one on the market are brittle with the results you can imagine..... Quote Link to comment Share on other sites More sharing options...
