Luma Posted July 19, 2016 Share Posted July 19, 2016 So my Santana SIIA rebuild moved on with dismantling of the engine. The bore wasn't worn too bad but still had enough ridge to cause me a problem when trying to get the fourth piston out. ( the rings got stuck behind the ridge and couldn't get past it so I had to sandpaper it a bit to make it pass) Also the bore was original size. (90,47mm) The crack running alongside the cylinder block wich I mentioned in my other post was tested once again, connected to tap water via hose. The water should be around 4 bar (56psi) pressure, and it still didn't leak. However I wanted to be sure, and decided to swap the block. I had 2.25 diesel engine laying in the corner of my garage for years and after some inspection, it turns out that it has been bored to 0.020 so now it's around 91 mm bore, and also it has no ridge at all, almost as good as new Since the blocks on 2.25 petrol and diesel are the same I decided to complicate my engine rebuild a bit more and swap all the petrol components to this diesel block So I started the disassembling. Besides one nut on the crankshaft journal (prob overtightened) it wasn't too hard of a job since the pistons and conrods were already out and most of the other nuts were tightened by hand. Here it is, naked block with just main bearings in it I did the same thing with my petrol engine the next day, having bit of a problem with getting tappet assembly out, the tappet guide was kinda stuck inside so I tapped with hammer gently and wasted alot of WD-40 , also payed a bit more attention when removing the camshaft, but it still wasn't more than 3 hours of work... Here are both engines. The one further away, on the floor is diesel block and elevated one, closer is petrol. Diesel crankshaft. I wrapped it in rags to prevent any damage, you can never be too sure, and well, who knows I might need a Diesel crankshaft some time soon And this is Petrol crankshaft. They appear to be the same although apparently they are not. The big "P" stamped on it stands for Petrol? Okay so here is my problem. This is the main bearing wich I wound in the Diesel block, on the diesel crankshaft: As you can see, It says 010 U/S. I suppose that stands for 0.010" undersize. But the thing is my manual says that only petrol engines have undersizes, so what is this bearing doing in here? And this is the main bearing shell from the petrol engine: It says STD meaning standard. So is this okay, or is every petrol engine supposed to have undersize? Wich bearing should I order when I start putting this back together (with the petrol crankshaft obviously) STD, 010 U/S or something else? How can I accurately measure wear without some special tool? Also, I do need to put main bearing cap from the petrol engine onto it, right? What about the tappet assemblies? obviously I will put the slider and the pushrods from petrol back in but what about tappet guide? Petrol or Diesel? Oh, and is this flat part on the camshaft normal? it doesn't seem to be worn ,more like it's machined 1 Quote Link to comment Share on other sites More sharing options...
Luma Posted July 25, 2016 Author Share Posted July 25, 2016 Very ****ing useful replies thanks alot this forum ****ing rocks Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 26, 2016 Share Posted July 26, 2016 Bye then. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 26, 2016 Share Posted July 26, 2016 Grumpy sod Les Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 26, 2016 Share Posted July 26, 2016 i did like his/her pictures, though. would liked to have helped, but don't know enough to comment. Hope they feel better soon. G. Quote Link to comment Share on other sites More sharing options...
Luma Posted July 27, 2016 Author Share Posted July 27, 2016 Sorry, had a bad day, I figured it all out myself Quote Link to comment Share on other sites More sharing options...
xychix Posted July 27, 2016 Share Posted July 27, 2016 Feel free to answer your own question then, might help someone else some random day. Hope for you you find help on other subjects here, welcome Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted July 27, 2016 Share Posted July 27, 2016 Just on the off-chance ... My impression is that most people on this forum who once had 'current' knowlwdge of S2A 2.25 engines have long ago moved on to different engines. Whether that was a good decision or not is another discussion. The forum that probably has more current interest and hands on knowledge of the 2.25 is the Series 2 Club forum. You don't have to be a Club member to post questions, or get answers. While my ID should still be active there, I am not, and it's probably best if you don't start 'I was recommended to this forum by D**** S*********' !! With that proviso, if you have more questions you might give them a try. I'm not sure whether the Santana word will help, or put people off because they don't know what differences there might be. Regards. Quote Link to comment Share on other sites More sharing options...
Luma Posted July 28, 2016 Author Share Posted July 28, 2016 Thanks, will try series 2 club,but my sereis will never get engine other than original Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 30, 2016 Share Posted July 30, 2016 someday I'll fit the original engine back - if I can find all the bits I kept when I cut them out to fit the tdi, the intercooler, the battery, ......... Quote Link to comment Share on other sites More sharing options...
