Cornish Rattler Posted October 1, 2016 Share Posted October 1, 2016 Hi guys I'm in the process of making a list of everything I need to convert a 1971 s11a swb to Disco 200 tdi engine and need to know what clutch assy I need to use, I am using the original 2a g/box Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 1, 2016 Share Posted October 1, 2016 Cover for the disco and then plate and thrust bearing for the gearbox. I don't know if you'll need to do any modifications though. Les Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted October 17, 2016 Share Posted October 17, 2016 My series 3 with disco engine was fitted with disco cover plate and diesel series centre plate. Series thrust bearing with no mods Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 17, 2016 Share Posted October 17, 2016 I would say the cover plate depends on the clutch. Using a SIII clutch system and bell housing allows the Tdi cover plate with a SIII friction plate. But the different clutch system of a SII or IIA could require the older cover plate, and that in turn limits the friction plate choice. If that is true, then use the HD friction plate, which I think is 9" for the SII. Quote Link to comment Share on other sites More sharing options...
Pepé le Pew Posted October 18, 2016 Share Posted October 18, 2016 With a 2a gearbox and clutch withdrawal mechanism you can use the late 2a 9.5 inch cluth cover (part number 571228) and the 9.5 inch late 2a/3 clutch plate (FRC2297). Eric. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted October 28, 2016 Share Posted October 28, 2016 I always use the original type to suit gearbox, so my 88 has a full Series 3 clutch, my 109 has a Defender clutch, did a friends S2 and used a full S2 clutch on that. Never have mixed and matched Quote Link to comment Share on other sites More sharing options...
