jericho Posted December 3, 2006 Share Posted December 3, 2006 My newly installed defender style lt77 is reluctant to select reverse. The little spring loaded plunger next to the gear lever with a ball bearing thingy is jamming up.Took it apart to clean it,that didn't help,but the ball looked slighty non-round. Should I replace the ball,or the whole unit? What is this part called? Any suggestions? Thanks. Quote Link to comment Share on other sites More sharing options...
western Posted December 3, 2006 Share Posted December 3, 2006 thats the detent housing, the ball bearing is available seperatly part number is 571146, does it engage reverse with that part off the vehicle, if not it could be a badly adjusted reverse light switch causing the problem. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 4, 2006 Share Posted December 4, 2006 If you screw the reverse light switch in too far it can prevent you from selecting reverse gear at all. Les. Quote Link to comment Share on other sites More sharing options...
Jon White Posted December 4, 2006 Share Posted December 4, 2006 If you screw the reverse light switch in too far it can prevent you from selecting reverse gear at all.Les. Been there done that!!!!!! Jon Quote Link to comment Share on other sites More sharing options...
michael calvert Posted December 4, 2006 Share Posted December 4, 2006 mine was the little grub screw actually holding down the linkage onto the selctor fork in the top of the box, abit of locktite solved that one Quote Link to comment Share on other sites More sharing options...
GBMUD Posted December 4, 2006 Share Posted December 4, 2006 Been there done that!!!!!! Jon Ditto. Chris Quote Link to comment Share on other sites More sharing options...
SteveG Posted December 4, 2006 Share Posted December 4, 2006 What you've been there and done that twice Chris or you've done a 'Ditto' before? - I'm confused! Steve Quote Link to comment Share on other sites More sharing options...
jericho Posted December 4, 2006 Author Share Posted December 4, 2006 thats the detent housing, the ball bearing is available seperatly part number is 571146, does it engage reverse with that part off the vehicle, if not it could be a badly adjusted reverse light switch causing the problem. Yes,it works with that part removed. Top info. Thanks very much. Quote Link to comment Share on other sites More sharing options...
western Posted December 4, 2006 Share Posted December 4, 2006 Try with the plunger assembly refitted & the reverse light switch removed, if it still won't engage, the problem is elsewhere maybe inside the gearbox, your next best move would be to ring Ashcrofts for further advice/repair. Quote Link to comment Share on other sites More sharing options...
