Lewis Posted December 8, 2006 Share Posted December 8, 2006 The 110 trayback (aka that horrible yellow thing) is fitted with 35/10.50 tyres on 8spoke rims. Being a 110 it already has the turning circle (and stopping distance) of a supertanker, and the large tyres are only making it worse - at nowhere near full-lock the side tread on the tyres rub the radius arms We need to buy a 5th tyre and rim so I thought it would be best to change all of the wheels at once. Can anyone recommend a cheap steel wheel with a greater offset? The budget wont stretch to Mach 5's, nor would i want to risk treating them in the same way that i would an cheap rim - smashing a 30quid 8spoke/modular wouldnt bother me too much Thanks Lewis Quote Link to comment Share on other sites More sharing options...
will_warne Posted December 8, 2006 Share Posted December 8, 2006 Sorry Lewis, there's nothing off the shelf. If you want cheap its a case of reversing Disco rims or Modulars/8-spokes. I had the same problem.... Quote Link to comment Share on other sites More sharing options...
Lewis Posted December 8, 2006 Author Share Posted December 8, 2006 Sorry Lewis, there's nothing off the shelf. If you want cheap its a case of reversing Disco rims or Modulars/8-spokes. I had the same problem.... Damn, thats a bit inconvenient Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted December 8, 2006 Share Posted December 8, 2006 Be aware that modulars / 8-spokes come in a range of offsets - have a look at where the disc lands on the hoop (on your wheel, if that makes any sense), and then you're into grappling with whether your measurement of offset is the same as everyone else uses... Quote Link to comment Share on other sites More sharing options...
Lewis Posted December 8, 2006 Author Share Posted December 8, 2006 Be aware that modulars / 8-spokes come in a range of offsets - have a look at where the disc lands on the hoop (on your wheel, if that makes any sense), and then you're into grappling with whether your measurement of offset is the same as everyone else uses... Sorry, its probably definately me being a bit thick, but i didnt understand any of the above Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted December 8, 2006 Share Posted December 8, 2006 Probably me, it's Friday. Large-text version: The schematic wheel is made of a disc (with holes in it for wheelnuts, hub etc) welded into a hoop which carries the tyre. Mangels make the 8-spoke in a range of offsets, I had a set from Sinton which were silly, 750 SAGs were outside the bodywork on a Series! Quote Link to comment Share on other sites More sharing options...
nas90 Posted December 8, 2006 Share Posted December 8, 2006 The budget wont stretch to Mach 5's, nor would i want to risk treating them in the same way that i would an cheap rim - smashing a 30quid 8spoke/modular wouldnt bother me too much The whole point of Mach 5 rims is that a racer builds them for racers. So they are tough. You must try very hard to break a Matt Lee rim! Quote Link to comment Share on other sites More sharing options...
Lewis Posted December 8, 2006 Author Share Posted December 8, 2006 The whole point of Mach 5 rims is that a racer builds them for racers.So they are tough. You must try very hard to break a Matt Lee rim! Regardless of strength I can buy three 8 spoke/modulars for every one Mach 5, I find it hard to believe they could possibly be 3 times stronger. IMHO ~£120 for one wheel is ridiculously over priced. The aim of this truck is to be competitive for under £5grand and I cannot justify the best part of a thousand pounds on 5 (unpainted) wheels, possibly in the future but certainly not right now The above seems to have come out as a bit of a rant but please dont take it that way, its just my very humble opinion, and all input is gratefully received Lewis Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 8, 2006 Share Posted December 8, 2006 The whole point of Mach 5 rims is that a racer builds them for racers.So they are tough. You must try very hard to break a Matt Lee rim! hmmm doesn't exactly tally with some of the stories I have heard about Mach 5's always worth doing a search on these things to find "a variety of opinions" Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted December 8, 2006 Share Posted December 8, 2006 I run 36/10.50x16 on modulars and had the same trouble with lock. I fitted 30mm spacers. I know people don't like them but they are the same as running a wheel with more offset as far as extra leverage over steering/wheel bearings are concerned. Ive heard people saying they come loose but I check mine every time I have the wheels off and they have never needed to be tightened. think it depends on how well you clean the hub before you fit them. The problem I did find was the extra offset caused the tyre's to rub the bodywork everywhere but Ive tray backed it now and moved the front wheel arch's up 2 inch's. Quote Link to comment Share on other sites More sharing options...
Lewis Posted December 8, 2006 Author Share Posted December 8, 2006 I run 36/10.50x16 on modulars and had the same trouble with lock. I fitted 30mm spacers. The problem I did find was the extra offset caused the tyre's to rub the bodywork everywhere but Ive tray backed it now and moved the front wheel arch's up 2 inch's. Hmm, I had considered spacers but I always thought of them as a bit of a bodge - fixing the symptoms rather than curing the problem Did you get steel or alluminium spacers? where were they from and how much? Clearance is not really an issue as its trayback with no arch spats on the front (they'll probably get replaced by some conveyor belt) plus the suspension doesnt seem to move - spring weights need investigating methinks Quote Link to comment Share on other sites More sharing options...
filthy boy Posted December 8, 2006 Share Posted December 8, 2006 Hmm, I had considered spacers but I always thought of them as a bit of a bodge - fixing the symptoms rather than curing the problemDid you get steel or alluminium spacers? where were they from and how much? Clearance is not really an issue as its trayback with no arch spats on the front (they'll probably get replaced by some conveyor belt) plus the suspension doesnt seem to move - spring weights need investigating methinks Spacers or changing the wheel offset / backspace has the same effect on the wheel bearing loads and scrub radius. Quote Link to comment Share on other sites More sharing options...
Henry Webster Posted December 8, 2006 Share Posted December 8, 2006 Definitely have a look at the eight spokes. I've seen at least two different offsets on otherwise identical rims. Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted December 8, 2006 Share Posted December 8, 2006 Ask Gwyn Lewis as hes got some with a very big offset on his Disco. Paul Quote Link to comment Share on other sites More sharing options...
Lewis Posted December 9, 2006 Author Share Posted December 9, 2006 Thanks for all the suggestions guys Definitely have a look at the eight spokes. I've seen at least two different offsets on otherwise identical rims. Has anyone got an supplier info on these? Cheers Lewis Quote Link to comment Share on other sites More sharing options...
simonr Posted December 10, 2006 Share Posted December 10, 2006 <Hijack> Do you know if you can get Simex in rim sizes bigger than 16"? There is a big difference in weight between 15" & 18". Wondered if you can get 18" or something like that & save a few extra Kg? </Hijack> Si Quote Link to comment Share on other sites More sharing options...
