trod Posted August 29, 2017 Share Posted August 29, 2017 hi can any one tell the differance between a lwb & a swb steel rim. thanks Trod Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 29, 2017 Share Posted August 29, 2017 There's a lot of variation, but I believe usually SWB are 5.5" wide whereas LWB are 6.5" wide. Quote Link to comment Share on other sites More sharing options...
AV8R Posted August 29, 2017 Share Posted August 29, 2017 To the best of my knowledge Series 88"WB had only 5 " wide rims. The LWB's had 5,5" wide rims. The 6,5 " rims were only for the Forward Controls and the 109" 1 Ton version. These vehicles used 9.00 x 16" tyres . Special ratios in the transfer case was fitted to cope with the larger diameter tyre. Quote Link to comment Share on other sites More sharing options...
xychix Posted August 29, 2017 Share Posted August 29, 2017 8 hours ago, FridgeFreezer said: There's a lot of variation, but I believe usually SWB are 5.5" wide whereas LWB are 6.5" wide. I just swapped to 16" 6.5 Wolfrims and these are 'clearly' wider than my previous original series III 109 station sahara rims. can measure tomorow. Quote Link to comment Share on other sites More sharing options...
xychix Posted August 31, 2017 Share Posted August 31, 2017 hmmm I measure just over 16cm from outer edge to outer edge, which converts to 6.29" on the older rims. However the wolf ones I ordere are clearly wider! I'd guess they should be 6" then? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 31, 2017 Share Posted August 31, 2017 I think rim width is measured to the inner mounting surface, where the bead goes, otherwise alloy wheels, and steel wheel would have different 'widths' due to the material thicknesses... Quote Link to comment Share on other sites More sharing options...
xychix Posted September 2, 2017 Share Posted September 2, 2017 ah yeah that makes sense, I'll stick with 6" then Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 2, 2017 Share Posted September 2, 2017 SWB 5", LWB 5.5, 1-Ton and FC are both 6", I think (different offsets, FC having the wheel further outboard). HD (aka Wolf) are 6.5". Discovery steel wheels are 7", like LR alloy wheels. Quote Link to comment Share on other sites More sharing options...
