Glue Posted October 13, 2017 Share Posted October 13, 2017 I'm in the process of re-instating the rear wash and wiper on my 110. I've fitted the wiper motor and that works when I I flash it out with the battery, and it works if I plug directly into the loom now I've replaced the (broken) switch with a new Carling one. I just need to build a short loom to fit between the door and the light cover. So I moved onto the wash function... I've pulled the hose from the jet over the door and blown that through. I put the hose back and checked the connection to the pump on the reservoir. Feeling confident I pushed the button and was slightly dismayed to watch the roof lining over the passenger door start raining! Clearly I need to replace the pipework. Can anybody confirm that it's 3/16" or 4mm diameter and tell me how much I need. Piece of string measurement suggests 5m will be enough. Glue Quote Link to comment Share on other sites More sharing options...
Peaklander Posted October 13, 2017 Share Posted October 13, 2017 There’s a joint in the pipe just above the passenger door so I’d check that first. Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted October 14, 2017 Share Posted October 14, 2017 As Peaklander said, there is a joint above the headliner above the passenger door. It is normally a non return valve. Mine was thre wrong way round but had been working for years! Quote Link to comment Share on other sites More sharing options...
AMB Posted October 14, 2017 Share Posted October 14, 2017 Agree - check non-return valve over front passenger door. On mine the valve body had split. Quote Link to comment Share on other sites More sharing options...
simonpelly Posted October 14, 2017 Share Posted October 14, 2017 Fitted a new non-return value some time back. The original one was fitted back to front. Here are some notes: http://pellylandroverdefender.blogspot.co.uk/p/start-of-refit.html Hope it helps, Simon... Quote Link to comment Share on other sites More sharing options...
Glue Posted October 15, 2017 Author Share Posted October 15, 2017 Many thanks Folks, I guess the headlining's coming out tomorrow Glue Quote Link to comment Share on other sites More sharing options...
western Posted October 15, 2017 Share Posted October 15, 2017 No need to pull the complete headliner out, just remove the left sunvisor & its 2 screws, pull the plastic rivet fir tree fasteners from above the door & ease headliner down, take the screen pillar trim off & ease the washer tube out from behind & from roof, Non Return Valve [NRV] just pushes into the tubing. Quote Link to comment Share on other sites More sharing options...
simonpelly Posted October 17, 2017 Share Posted October 17, 2017 When pushing the valve onto the tubing found that heating it up briefly with a heat gun helped a bundle. Quote Link to comment Share on other sites More sharing options...
