ianmayco68 Posted April 21, 2018 Share Posted April 21, 2018 Hi all , I’ve had the day from hell, went to work before I even started at 6 I turned rough and walked straight into the wire feed unit and cut my head I thought the stars were out for a while then various other things went tits up and finally the last straw . I was sorting a clutch problem ( see another thread ) stripped it down old slave cylinder felt ok but thought no I’ll fit the new trw one , that’s when the problems started fitted the clip with the rod then the slave was very tight going in had to wind it in using the bolts and wiggle it about to get it in , tried bleeding the clutch the fluid started coming out of the drain hole in the bell housing took it apart and the rod has gone into the bell housing and I want to cry . So would I be able to get the gearbox back enough to let it drop out without taking the seat box out ? Please someone tell me I can not it’s a shower and some Guinness. cheers Ian Quote Link to comment Share on other sites More sharing options...
ballcock Posted April 21, 2018 Share Posted April 21, 2018 Could you try a magnet on a wire? Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 21, 2018 Share Posted April 21, 2018 As above magnet in through the slave hole ( Hmm ..........that just dont sound right ) 2 Quote Link to comment Share on other sites More sharing options...
western Posted April 21, 2018 Share Posted April 21, 2018 try magnet on a bent wire coat hangar, just make sure the magnet cannot fall off the wire or your defo loking at a engine/gearbox split. have a beer anyway to ease the days pains Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 21, 2018 Author Share Posted April 21, 2018 I'm on my second Have already took the props off and undone all the floor plates the new slave cylinder didn't feel rite when I put the actuator rod in and pushed it in , it stayed in were as the old one sprung back out . cheers Ian Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 22, 2018 Author Share Posted April 22, 2018 Well lucked changed today borrowed one of these magnet on the end got it out 1st go will definitely be purchasing one, but the got attacked by a huge bumblebee so come in for a cuppa . 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 22, 2018 Share Posted April 22, 2018 Have you removed the pistons from each slave to make a comparison? You may find something very simple. Failing that, you could swap the pistons, or at least the seals, if there is a cylinder fault. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 22, 2018 Author Share Posted April 22, 2018 I refitted the old slave cylinder Nick and all's well , the new one which was a TRW appeared to not have the spring behind piston so when the rod was pushed in it stayed there and the seal around the end was very , very tight going into the opening for it , had to wind it in using the bolts . Will take it apart next week and see what's up with it . Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 23, 2018 Share Posted April 23, 2018 The SIII slaves didn't have return springs either. My slave came off a Discovery Tdi. I wonder if it was only Discoverys that had it, then, and not Defenders? It'd just stop a bit of release bearing chatter and reduce the pedal dead band a touch, but isn't essential. Could be penny pinching by TRW in modern times, too. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted April 23, 2018 Share Posted April 23, 2018 Check the part number on the TRW slave - they all look the same across the models/engine types but some are slightly wider and only go in with force, which usually ends with the rubber seal being pulled back as it doesn't want to go in the hole, popping the rod out. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 23, 2018 Author Share Posted April 23, 2018 That’s what happened to me Eightpot , part number was correct 591321g but it did say on the box that it was for defender up to 1990 , but the older one was snug but not to the point that I had to force it in . Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2018 Share Posted April 23, 2018 7 hours ago, ianmayco68 said: That’s what happened to me Eightpot , part number was correct 591321g but it did say on the box that it was for defender up to 1990 , but the older one was snug but not to the point that I had to force it in . That's the one I have used, the rubber boot just wiggles through the hole without coming of & my current one is a TRW item Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 23, 2018 Author Share Posted April 23, 2018 This one was well tight Ralph , had to really wiggle it to get it out and I tried to wiggle it to get it in but it wouldn’t have it hence winding it it with the bolts . Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2018 Share Posted April 24, 2018 Lets hope its fitted to stay for a long time then & doesn't have to come out again. Quote Link to comment Share on other sites More sharing options...
