trickydicky Posted May 26, 2018 Share Posted May 26, 2018 hi all I'm upgrading the defender with real brakes ( disks on the rear )and thought id change both axles at the same time as my front axle has an advisory on excessive rust in the spring mounts .iv noticed the new front axle has a FRONT AXLE HARMONIC DAMPER on the diff .can anybody tell me if its worth keeping on or do you guys think I'm better off removing it ? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted May 26, 2018 Share Posted May 26, 2018 I've taken it off the axle on 45 with no ill affects. Mike Quote Link to comment Share on other sites More sharing options...
trickydicky Posted May 26, 2018 Author Share Posted May 26, 2018 any idea why it was fitted ? Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted May 26, 2018 Share Posted May 26, 2018 I fitted mine to the 90 and noticed no difference whatsoever. Why were they fitted, dunno but when I was driving a Discovery 1 as a company car it seemed to make a difference under braking at motorway speeds, if when braking the things hit bumps the front axle shuddered and bounced, those with the damper didn't do it. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted May 26, 2018 Author Share Posted May 26, 2018 wow that's interesting I'm running on military tyres and hd springs as I carry a roof tent and it can get a bit rough when going over bumps perhaps this could help a little . Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted May 26, 2018 Share Posted May 26, 2018 Its hard to say without insider information, I'm sure LR fitted them for a reason BUT as I said - on my 90 I can't feel the slightest difference. The addition happened when Discoveries etc were making that transition from semi agricultural work vehicles to fashion accessories where the users demanded a bit of refinement. Possibly softer spring rates / heavier engines / softer users / alloy wheels etc meant the damper was more significant ? Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 26, 2018 Share Posted May 26, 2018 I have one on my soft dash RRC. I suspect it was fitted from the introduction of the 300Tdi and R380, possibly only for RR and Discovery higher spec models. The Discovery 2 has a mass balance on the back of the LT230 that the Defender never had (along with the less successful dual mass flywheel), so LR only fitted these things to the more refined vehicles. Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted May 26, 2018 Share Posted May 26, 2018 53 minutes ago, Snagger said: (snip) so LR only fitted these things to the more refined vehicles. Or... LR only fitted these to vehicles they were trying to make more refined :-) The timing of the 300TDi / R380 seems about right, we bought a few Discoveries at about that changeover and from new only some were fitted with the damper, we had two vehicles retrofitted with them and the drivers stated that they were better with them. (I've still got the number plates for one of them in the shed somewhere, it ended its life upside down after some spirited action) 1 Quote Link to comment Share on other sites More sharing options...
toenden Posted May 26, 2018 Share Posted May 26, 2018 9 hours ago, Snagger said: I have one on my soft dash RRC. I suspect it was fitted from the introduction of the 300Tdi and R380, possibly only for RR and Discovery higher spec models. The Discovery 2 has a mass balance on the back of the LT230 that the Defender never had (along with the less successful dual mass flywheel), so LR only fitted these things to the more refined vehicles. Ny parents defender td5 from 2000 has the balanceblock in the lt230 so it did make it to some defenders 😀 /mads Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 26, 2018 Share Posted May 26, 2018 My early and late '91 RRC had them, so definitely not just 300TDI on. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted May 26, 2018 Share Posted May 26, 2018 All four discos I've owned had them they were all 200tdis 92-93. Mike Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted May 27, 2018 Share Posted May 27, 2018 My 300tdi's with a mixture of with/without were all commercial SVO builds and IME that means made of whatever bits were lying around - so I agree not the best data to work with. Quote Link to comment Share on other sites More sharing options...
