Arjan Posted June 24, 2018 Share Posted June 24, 2018 Right..... As you guys know about everything Land Rover, what is this injection pump ? Also, there is a 2nd lever that moves a bit between the 2 springs Engine is Ex lateish Disco 1 No wire to any of the injectors Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 24, 2018 Share Posted June 24, 2018 Throttle position sensor. Part of the EGR system I believe. Quote Link to comment Share on other sites More sharing options...
western Posted June 24, 2018 Share Posted June 24, 2018 EGR or EDC sensor, Quote Link to comment Share on other sites More sharing options...
monkie Posted June 24, 2018 Share Posted June 24, 2018 EDC - Electronic Diesel Control. " The EDC engine has a different fuel injection pump which connects to the accelerator through an electronic signal as opposed to the standard steel cable. It is more common on the Discovery 300Tdi. " Taken from here Quote Link to comment Share on other sites More sharing options...
cackshifter Posted June 25, 2018 Share Posted June 25, 2018 Im with retroanaconda, its the throttle position sensor potentimeter from an Egr system. What monkie says is true, but that isn't one of them. It will still have a throttle cable. That sensor can be removed, leaving a couple of prongs to drive it Quote Link to comment Share on other sites More sharing options...
monkie Posted June 25, 2018 Share Posted June 25, 2018 6 hours ago, cackshifter said: Im with retroanaconda, its the throttle position sensor potentimeter from an Egr system I've always thought that it was to do with EDC, but found this and you are right.... Quote Link to comment Share on other sites More sharing options...
Arjan Posted June 25, 2018 Author Share Posted June 25, 2018 Thanks you all ! Quote Link to comment Share on other sites More sharing options...
