Oil from water pump bolt hole
Which engine ?
if it's a 2.5N/A diesel then in parts book the water pump fixings look to be all bolts.
on my Defender spec 200tdi that hole has a long stud for timing case & water pump. IIRC it does screw into a hole that has oil on the block side. as the stud did have oil traces on it during my strip/rebuild back in Nov last year. [photo below]
Thanks, Ralph.
Yes the engine is a 12J. Turns out that After I put the new gasket on the water pump continued to leak out of the weep hole. Time for a new pump. This one was only two years old with not many miles on it.
Are water pumps a short lived item?
Thanks,
Colin
When I did timing belt last year I was advised to do water pump too as it’s seen as a “serviceable item” so I’m guessing they don’t have a great life span. 😊👍
