Arjan
How to make / fold this lifting roof section ?
This is really, really scary....
Let me go out and measure again.....
The outside dimensions are 120 x 180 cm and put on the floor, 10 cm high ?
Share this post
Link to post
Yes that's correct the corners are square and not rounded as in your example pictures
Regards Stephen
Share this post
Link to post
Hi Stephen,
Just back from measuring the cage again.
Length wise it is just perfect.
However, It is 60 mm. ( 6 cm.) too wide to fit in between the cage....
Deep Sigh....
Share this post
Link to post
remove 60 mm from the middle , then use the cutout section to join the 2 half's together with sikaflex and poprivets ....
Share this post
Link to post
So you need it to be 1.14m to the outside I could probably sort that out and then tig the corners up if your happy with that
Regards Stephen
Share this post
Link to post
So just been measuring outside myself I can get it to the width you want but how deep does it need to be because making it to the 1.14 means one of the long sides will be only 6cm deep looking at your pictures this might be ok
Regards Stephen
Share this post
Link to post
What are the chances of making it 60 mm smaller ?
Would be such a waste to not use this.....
Share this post
Link to post
Hi Stephen,
Let me think on this as I really need the "box" to be about 10 cm high for the gas struts, fabric etc. to go in etc..
Share this post
Link to post
BTW - "Borders" as in Dumfrieshire...
or more to the east ?
Share this post
Link to post
Forum Relay would be very nice...
It is roughly 2,400 miles to go and get it by car - I'm not sure about hand carrying this on board a plane these days 😁
... in the old days I 'flown with about anything you can think of.
.... and some...
Share this post
Link to post
More to the east close to Berwick upon Tweed if you need 10cm deep I will anneal the existing fold and straighten it out failing that I could tig a section of aluminium in to get you sorted
Regards Stephen
Share this post
Link to post
Stephen,
You're an ACE !!!!!!!!
Do you have a landline tel no I can contact you on please ?
Ideally, we could relay it a bit South...
Share this post
Link to post
I can hold it in Southampton if it can get down here. I shall be going to Newbury sort out and hopefully adventure overland show. If that helps.
Mike
Share this post
Link to post
Southampton would be really good - but how are we going to get it South ?
Share this post
Link to post
Arian let me do the mods and then I will pm you a contact no. What sort of time frame are you looking at.
Regards Stephen
Share this post
Link to post
Awesome !
Thank you very, very much !!!!
No hurry whatsoever..
I'll be at the LATP in August with the 88" and ,if need be, I can come north to collect it - no problem.
It will go on the cage OK so transport should be no problem.
Again, thank you very, very much !!!!!
Share this post
Link to post
No worries - I didn't know either until I was told to go...
Leafers At The Pitt
a somewhat "different" event I was told " Series only  " I am to go to with a friend, bringing 2 Series vehicles over.
( Apedale Valley Light Railway (near Newcastle-under-Lyme, Staffordshire) www.avlr.org.uk )
Will be only some 400 kms going North and I could sleep with friend near Edinbrugh.
You're sure it is not too much of an hassle to modify the panel ?
Share this post
Link to post
I’m happy storing it if needed! Can’t offer to move it anywhere, but can’t store until Newbury? I’m about 15miles north of the sortout.
Share this post
Link to post
Thanks !!!!!!
Let 's see how this goes.
I really don 't mind taking the Series up North.
In fact, it will be a very, very special opportunity to take the vehicle back to where I found it back in 1978..
Share this post
Link to post
So sorting out the mods for Arjan's roof this week. I have spoken to one of the young guys I work with who competes in motocross events throughout the UK and he is prepared to transport the roof section southwards as far as I'm aware he competes in Wales and at some point later in the year down at Portsmouth . He is away for a couple of weeks at the moment but when he gets back I will post a list of venues he is racing at and hopefully a forum member will be able to meet and collect roof section to help it further South. Will keep you posted
Regards Stephen
Share this post
Link to post
Wales would be very, very good as LATP is in the Midlands.. sort of
Share this post
Link to post
Thanks you Guys !
Share this post
Link to post
