ThreeSheds Posted June 14, 2019 Share Posted June 14, 2019 Hi, I am replacing the brake hoses on my D2 with SS braided ones, but can't find any for the body to chassis links under the near-side wheel arch. The problem is the fitting which needs to be like the picture on both ends of each hose... Any advice would be welcomed! Oh, and they need to be about 8" long since I will be doing a body lift soon... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 14, 2019 Share Posted June 14, 2019 David at llama 4x4 will make whatever you want... Alternatively so will any decent motorsports place. 1 Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 5, 2019 Share Posted July 5, 2019 Wot Bowie said - David can make anything. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted July 14, 2019 Author Share Posted July 14, 2019 I found more corrosion on the abs down pipes. I cut one and started to cut another before I realised that the whole triplet can be wiggled out as a unit if you de-rivet the bottom bracket under the wing... Quote Link to comment Share on other sites More sharing options...
