rtbarton Posted July 30, 2019 Share Posted July 30, 2019 Did you specify the vehicle rather than CCA/Ah ? I'd still have a go through Trading Standards, even if you don't expect a favourable result the supplier may already be on TS's radar, and it's all grist to the mill. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 30, 2019 Share Posted July 30, 2019 CCA/Ah shouldn't make a massive difference for a basic Series, it's a very light load compared to modern stuff and almost any battery should start & run a Series without exploding within the warranty period. I ran around with a second hand Mini Metro battery in the 109 for quite a while back in the day, that was "only" a Halfords battery too, and it was starting a V8. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 30, 2019 Share Posted July 30, 2019 So, with all the advice on here, you are still going back to an online supplier? Quote Link to comment Share on other sites More sharing options...
neilc Posted July 30, 2019 Author Share Posted July 30, 2019 No this supplier is literally 5 minutes up the road , I just thought I'd get a bit of feedback from him via the Webchat . 2 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 30, 2019 Share Posted July 30, 2019 Ah, fair fair play Quote Link to comment Share on other sites More sharing options...
neilc Posted July 30, 2019 Author Share Posted July 30, 2019 And screenshot it and send it to the original seller 😎 Quote Link to comment Share on other sites More sharing options...
Escape Posted July 31, 2019 Share Posted July 31, 2019 As above, did you order a specific type of battery (i.e. Ah and CCA) or one that will fit your car? While a bigger battery is always better, as Fridge says a smaller one (and 74Ah is not that small) should be perfectly fine in a Series. So I don't think that's the problem. Filip Quote Link to comment Share on other sites More sharing options...
