Kurtmifsud Posted September 24, 2019 Share Posted September 24, 2019 Hi all, I'm still new to the LR world. I am currently replacing the swivel balls on my defender Puma and have noticed that the CV joints are knackered. The LR diagrams show that these have to be replaced together with the half shafts. Do the CV joints match the TD5? or is there nay other option for a good replacement? Also will you go for britpart, bearmach or any other as Land Rover Original are quite expensive? Cheers Kurt Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 24, 2019 Share Posted September 24, 2019 CV joints are one of the few Britpart components that are good, or at least were. I had some for my RRC and they have been great. Ashcroft Transmissions did destructive tests on a range of CV brands and Britpart came second only to their own very expensive version. But that was all a decade or so ago. Hopefully, they haven’t changed much. Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 25, 2019 Share Posted September 25, 2019 CV's don't usually have to be replaced with a half shaft, they do come apart. But I notice that there doesn't seem to be a part number just for the CV joint now. If anyone would know it would be Ashcroft Transmissions, I'd drop them a line and see what they say, failing that buy a Britpart (cheap) Td5 type CV and see if it fits. .. I just checked the stub axle part number from a late Td5 to a TDCI and they are the same part, so Its a good assumption the CV joint is the same. Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted September 27, 2019 Share Posted September 27, 2019 TDCI cv joints dont come off the shafts, so you can either replace with a TD5 shaft & CV or just buy a TDCI shaft & CV assembly Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 27, 2019 Share Posted September 27, 2019 1 hour ago, RedLineMike said: TDCI cv joints dont come off the shafts, so you can either replace with a TD5 shaft & CV or just buy a TDCI shaft & CV assembly Is that the outer shaft that is integrated, or the inner shaft too? Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 27, 2019 Share Posted September 27, 2019 1 hour ago, RedLineMike said: TDCI cv joints dont come off the shafts, so you can either replace with a TD5 shaft & CV or just buy a TDCI shaft & CV assembly I find that a little hard to believe. But alas I've not played with a later defender set-up. Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted September 27, 2019 Share Posted September 27, 2019 1 minute ago, Maverik said: I find that a little hard to believe. But alas I've not played with a later defender set-up. your welcome to find it hard to believe, i thought the same until i ended up with a ****ed cv joint & a shaft that TD5 CVs dont fit, Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted September 27, 2019 Share Posted September 27, 2019 19 minutes ago, Snagger said: Is that the outer shaft that is integrated, or the inner shaft too? i cant remeber the exact difference but i do remember that it took smashing the cv joint inner to get it off the shaft, which i then discovered that a td5 cv doesnt fit the tdci shaft Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 27, 2019 Share Posted September 27, 2019 I see - its not that it wont come off the shaft - its that a Td5 CV joint isn;t compatible with a TDCI half shaft... Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted September 27, 2019 Share Posted September 27, 2019 3 minutes ago, Maverik said: I see - its not that it wont come off the shaft - its that a Td5 CV joint isn;t compatible with a TDCI half shaft... your welcome to try taking the cv joint off the shaft without damaging it, the main issue i remember is it uses a square section circlip rather than a round section circlip. the square section circlip is what stops you removing the cv joint once its assembled, Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 27, 2019 Share Posted September 27, 2019 1 hour ago, RedLineMike said: your welcome to try taking the cv joint off the shaft without damaging it, the main issue i remember is it uses a square section circlip rather than a round section circlip. the square section circlip is what stops you removing the cv joint once its assembled, Ouch - another LR cost saving scheme no doubt. Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 27, 2019 Share Posted September 27, 2019 So, whenever fitting new shafts or CVS, check you have a round section clip, replacing a square one if needed! That’s basically an act of fraud by LR. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 28, 2019 Share Posted September 28, 2019 That’s a bit of a crappy design then! Can’t see how the square section is of benefit to them! Guessing with the shaft in the CV you can’t get it tipped enough to get the balls out of the cv and get to the clip. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted September 28, 2019 Share Posted September 28, 2019 Just another engineering failure on the puma. I heard a horror story about a low miles defender, only 20k miles, where the main box spud shaft splines failed completely. 20k miles! So, this doesn't surprise me at all. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 28, 2019 Share Posted September 28, 2019 1 hour ago, Gazzar said: Just another engineering failure on the puma. I heard a horror story about a low miles defender, only 20k miles, where the main box spud shaft splines failed completely. 20k miles! So, this doesn't surprise me at all. Up to a certain point, the splines just weren't greased on assembly. So it it’s done 20k of short stop/start journeys it won’t take long to start the fretting between the splines. Quote Link to comment Share on other sites More sharing options...
