tolley Posted December 14, 2019 Share Posted December 14, 2019 what is the difference between the 1970 3.5 v8 and the SD1 v8 , are they a direct replacement for both . Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 14, 2019 Share Posted December 14, 2019 There were various flavours of the SD1 V8, but generally higher compression that the RR unit. Flywheels are different, water pump/accessory drive different, not sure much else. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 15, 2019 Share Posted December 15, 2019 Both are ancient now but SD1 had a lighter flywheel and likely different accessory drive etc. If the SD1 is an EFI then it'll have the EFi inlet manifold. SD1 exhaust manifolds are different. The oil pumps got bigger at some point but they're still not great compared to the later ones. Generally with a bit of faffing about you can bolt any Rover V8 in place of another. SD1 may well have a different cam for more power at higher revs with less low torque, depends what version the RR unit is as some were low compression or restricted. Here's some light reading for you: Quote Link to comment Share on other sites More sharing options...
smallfry Posted December 15, 2019 Share Posted December 15, 2019 It depends entirely what the engine/s was originally fitted to, which affects front cover, manifolds, sumps, pistons and camshafts. Heads are different too, along with emissions gear But basically, yes, the engines could be swapped, as all the above items could be swapped Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted December 15, 2019 Share Posted December 15, 2019 I fitted one to an 85 Vogue but when it was installed the whole pulley system was not alinghned before I could start it oone of the valves dropped and I couldn't get the engine to turn a full rotation. I then stripped the engine back and rebuilt the top end and fitted new camb shaft etc. Was a fantastic engine and ran well until I broke the car up. Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted December 19, 2019 Share Posted December 19, 2019 On 12/15/2019 at 9:11 PM, FridgeFreezer said: The oil pumps got bigger at some point but they're still not great compared to the later ones. If you can find the Buick V6 front cover it will have the uprated oil pump as standard fit and will fit onto your engine. Quote Link to comment Share on other sites More sharing options...
