Wowa Posted March 2, 2020 Share Posted March 2, 2020 1988, 110 2.5TD > 11L 200tdi. I assume the fancy (Goodridge) lines are just the short Flexi sections in the wheel wells. Is there such a thing as a replacement for the longer hoses. Specifically, I need the long section from drivers wheel well to passenger side (passes under radiator) NRC7801. Is this available as a Flexi line (cos bending and fitting original looks like a blast!!)? Thanks Quote Link to comment Share on other sites More sharing options...
Litch Posted March 2, 2020 Share Posted March 2, 2020 Yes, the Goodrich hoses are just the short flexi at the axle ends and also between the rear axle & chassis. If you don't want to make up your own brake-pipes then kits are available and should be obtainable over there (the Automec one gets good reviews). Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted March 3, 2020 Share Posted March 3, 2020 Dave at LLama 4x4 will make hoses to any length required, he did my complete car from the mastercylinder to calipers for about £150 Quote Link to comment Share on other sites More sharing options...
Mutley Posted March 3, 2020 Share Posted March 3, 2020 @RedLineMike...... I think he's in Canada??? Dave not so? 😁 Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted March 3, 2020 Share Posted March 3, 2020 1 hour ago, Mutley said: @RedLineMike...... I think he's in Canada??? Dave not so? 😁 id suspect that dave at llama would ship worldwide if you ask Quote Link to comment Share on other sites More sharing options...
Ex Member Posted March 3, 2020 Share Posted March 3, 2020 You can buy the hard lines from any supplier. Just look up the part number. They coil the long sections for shipping. You straighten them out. Get new clips at the same time. Quote Link to comment Share on other sites More sharing options...
western Posted March 3, 2020 Share Posted March 3, 2020 Fitting a new brake pipe to a TD 110 with the body & engine fitted is a real pig of a job, it was difficult enough replacing the pipe while I was doing my chassis change while the body & engine were out. I'm sure David of Llama 4x4 would be able to advise & sell you the correct amount of flexy hose to replace the hard pipe. He will need to know the correct length & what end fittings you need. Quote Link to comment Share on other sites More sharing options...
Wowa Posted March 4, 2020 Author Share Posted March 4, 2020 Thanks guys; Western you are right. A pig of a job now things are back in place. I have just ordered some copper nickel line, bender, flare tool etc for that long section. Apparently more forgiving and easier to bend to accomodate my usual assistant, my alter ego named 'Rage'. Into the wheel wells is the challenge. I figure 25' of tube will just about cover my patience level and I plan on mediating for a week before doing the job. I have a habit of turning the air a deep shade of blue early on! 1 Quote Link to comment Share on other sites More sharing options...
western Posted March 4, 2020 Share Posted March 4, 2020 That pipe took me 2 attempts to make, & I had the old one to follow as well. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted March 5, 2020 Share Posted March 5, 2020 There is an alternative route on the 300tdis - it runs along the bulkhead, then down to the chassis leg. I have changed two in situ, it's easier than the one in the picture, though needs a bit of wrestling, but the OP's master cylinder my well be on that side anyway if it's LHD Quote Link to comment Share on other sites More sharing options...
