Defender 110 panoramic window conversion
Hi all,
Iv just brought my first defender 110 and it has already had the panoramic glass conversion done. I’m trying to find out if it’s possible to have to put back to original as I’m not a massive fan. If so does anyone know any company’s that can do this?
thanks
I've got a pair of CSW rear panels off a 300Tdi 110 if you're desperate. One took a clout to the rear corner by, I assume a truck, when it was parked up so would need some bashing. Windows coud also do with a rebuild.
On 4/5/2020 at 10:09 AM, Badger110 said:
I always thought they were fitted over the existing panel to give the illusion of a complete glass panel...learn something new everyday
They are but they're bonded on, would be an absolute nightmare to remove without breaking it, you then have to source and fit the original side window assembly and probably repaint because you'll never get the adhesive off without ruining the paint so by the time you've done all that, sourcing a second hand set of sides is probably cheaper.
  • Thanks 1
