Sabre Posted April 16, 2020 Share Posted April 16, 2020 When I disassembled my 300Tdi engine, I also loosened the FIP shaft bolt, not knowing that said bolt could be left as is. Once the pump is installed, can I insert the locking pin into the timing slot, and tighten that bolt ? How much should I torque it to ? Thanks in advance Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 16, 2020 Share Posted April 16, 2020 You need to set the pump first if the pulley is loose, as the timing will be lost. There are videos on YouTube but basically you use a dial gauge in the rear of the pump and set the pump to the right point, and lock it - there is a facility to lock it. Then you fit it and time the pulley up with the pin. Then you can tighten the bolt and unlock the pump. Quote Link to comment Share on other sites More sharing options...
Sabre Posted April 17, 2020 Author Share Posted April 17, 2020 10 hours ago, cackshifter said: You need to set the pump first if the pulley is loose, as the timing will be lost. There are videos on YouTube but basically you use a dial gauge in the rear of the pump and set the pump to the right point, and lock it - there is a facility to lock it. Then you fit it and time the pulley up with the pin. Then you can tighten the bolt and unlock the pump. Thank you, appreciated Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 17, 2020 Share Posted April 17, 2020 Brittanica Restorations has a couple of videos, see '200/300Tdi VE injector pump. Removing the front seal and set timing' Quote Link to comment Share on other sites More sharing options...
Sabre Posted April 19, 2020 Author Share Posted April 19, 2020 On 4/17/2020 at 1:05 PM, cackshifter said: Brittanica Restorations has a couple of videos, see '200/300Tdi VE injector pump. Removing the front seal and set timing' Thanks will look, appreciated Quote Link to comment Share on other sites More sharing options...
western Posted April 19, 2020 Share Posted April 19, 2020 https://britrest.com/ & youtube page https://www.youtube.com/channel/UCRssffMP_F8_SCJcqFLq4Ow/channels Quote Link to comment Share on other sites More sharing options...
Sabre Posted April 19, 2020 Author Share Posted April 19, 2020 19 minutes ago, western said: https://britrest.com/ & youtube page https://www.youtube.com/channel/UCRssffMP_F8_SCJcqFLq4Ow/channels Thank you, will check 👍 1 Quote Link to comment Share on other sites More sharing options...
Eightpot Posted April 19, 2020 Share Posted April 19, 2020 The shaft is tapered and just undoing the nut doesn't necessarily loosen the pulley - if its still tight just put the nut back on Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted April 21, 2020 Share Posted April 21, 2020 On 4/19/2020 at 8:58 PM, Eightpot said: The shaft is tapered and just undoing the nut doesn't necessarily loosen the pulley - if its still tight just put the nut back on I was also thinking the same. If the pulley isn't loose or come off the tapered shaft you should just be able to tighten it back up. Steve 1 Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 21, 2020 Share Posted April 21, 2020 Well I did say "if the pulley is loose". If not, well I'm totally with you too, tighten it up and pretend it didn't happen. 1 Quote Link to comment Share on other sites More sharing options...
Sabre Posted April 27, 2020 Author Share Posted April 27, 2020 On 4/21/2020 at 9:38 PM, cackshifter said: Well I did say "if the pulley is loose". If not, well I'm totally with you too, tighten it up and pretend it didn't happen. Unfortunately the pump was out, pulley removed I had a look at the videos, and apparently it is only the 200Tdi that has a shaft locking bolt, not the 300Tdi Anyway, I have installed the pump, lined up the hole, and have fitted the timing belt. Should see in about 2 weeks if I'm let off the hook (pulley 😳) Thanks guys Quote Link to comment Share on other sites More sharing options...
Eightpot Posted April 27, 2020 Share Posted April 27, 2020 Think you'll be lucky to get away with that - from memory the way to set the pump up if the pulley has been removed is to use a depth gauge on the plunger and line the pulley and slot up when the correct depth has been reached. The pump shaft naturally springs past where it should be at tdc so you have to dial it back against spring pressure to the right spot Quote Link to comment Share on other sites More sharing options...
Sabre Posted April 29, 2020 Author Share Posted April 29, 2020 On 4/27/2020 at 7:22 PM, Eightpot said: Think you'll be lucky to get away with that - from memory the way to set the pump up if the pulley has been removed is to use a depth gauge on the plunger and line the pulley and slot up when the correct depth has been reached. The pump shaft naturally springs past where it should be at tdc so you have to dial it back against spring pressure to the right spot That's my thought as well. I took the pump off when the engine was at TDC, when I now installed it again, I turned the engine to TDC, and the slot in the FIP aligned. So I installed the timing belt in that position. Quote Link to comment Share on other sites More sharing options...
