kevin50 Posted July 14, 2020 Share Posted July 14, 2020 Just noticed I'm missing something, Bracket for wing to bulkhead, each side. looking at parts book it is MTC2136 but can't find any as they seem to be Absolete . Anyone got a pic ? might be able to make one up. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 14, 2020 Share Posted July 14, 2020 Like this? https://www.brit-car.co.uk/product.php/163406/928/wing_fender_mounting_bracket_top_def Quote Link to comment Share on other sites More sharing options...
western Posted July 14, 2020 Share Posted July 14, 2020 The top bracket from around 1987 became part of the wing top panel, my 1989 certainly has them as part of the wing top, not seperate items Quote Link to comment Share on other sites More sharing options...
kevin50 Posted July 14, 2020 Author Share Posted July 14, 2020 Think I'll have to try and make something up. Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 14, 2020 Share Posted July 14, 2020 Yeah I made some out of some box aluminium in the end, steel ones will make your wing top corrode unless insulated extremely well. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted July 14, 2020 Author Share Posted July 14, 2020 7 hours ago, Bowie69 said: Like this? https://www.brit-car.co.uk/product.php/163406/928/wing_fender_mounting_bracket_top_def Thanks mate even got the measurements too. 3 hours ago, Maverik said: Yeah I made some out of some box aluminium in the end, steel ones will make your wing top corrode unless insulated extremely well. Will have a go, Quote Link to comment Share on other sites More sharing options...
pete3000 Posted July 26, 2020 Share Posted July 26, 2020 I've got mine apart at the moment, will try to take a photo and some dimensions. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted July 26, 2020 Author Share Posted July 26, 2020 1 hour ago, pete3000 said: I've got mine apart at the moment, will try to take a photo and some dimensions. Still not done this yet, should of done it when I first put wings on, cant really see where they bolt to, hope I have not got to take everything back off. Im sure I should be able to get in there somehow, Pics would be Great, Thanks Mate Quote Link to comment Share on other sites More sharing options...
western Posted July 26, 2020 Share Posted July 26, 2020 in this area there should be 2 bolt holes, most likely have rivnuts in them to secure the bracket to bulkhead Quote Link to comment Share on other sites More sharing options...
pete3000 Posted July 26, 2020 Share Posted July 26, 2020 (edited) Note the 2 bolt holes 1 is slotted for alignment? new brackets below which fit from the rear pocket of the holes above, made from some 12mm x 2mm strip 65mm long, screws are M6 and should be 15mm long. Some length needs trimming off, as these are all I had in stainless. Hole centres are 42.5mm Old bracket for reference, other one is rotted out. 27mm wide and 92mm long hole centres are 42.5mm as above M6 nut welded onto rear...Bigger holes are 9mm The bracket linked above would work unless like me you have made your own. HTH Pete Edited July 26, 2020 by pete3000 Quote Link to comment Share on other sites More sharing options...
kevin50 Posted July 27, 2020 Author Share Posted July 27, 2020 2 hours ago, pete3000 said: Note the 2 bolt holes 1 is slotted for alignment? new brackets below which fit from the rear pocket of the holes above, made from some 12mm x 2mm strip 65mm long, screws are M6 and should be 15mm long. Some length needs trimming off, as these are all I had in stainless. Hole centres are 42.5mm Old bracket for reference, other one is rotted out. 27mm wide and 92mm long hole centres are 42.5mm as above M6 nut welded onto rear...Bigger holes are 9mm The bracket linked above would work unless like me you have made your own. HTH Pete Excellent Thanks for taking the time , will try and make something up with these Measurements. Quote Link to comment Share on other sites More sharing options...
