Defender 90 not starting
Flipper
I have a 1987 exMOD 90 with a 2.5 diesel .
Lockdown meant it hasnt been driven and when I came to fire it up not much happened....
I can hear a click (presumably the starter solenoid), when I put another battery pack onto to the existing battery and short the starter I manage to get it to start however its not a lasting solution or ideal for supermarket car parks.
The battery shows 12.84V after charging but once used to attempt to start (and failing) it drops to 9.4V .
Is this as simple as a new battery or should I be testing for something else as well ?
Any advice gratefully received.
See if you can borrow a reconditioning charger, check the battery fluid, top up if needed then put through a recon charge, other than that it sounds like your battery is a bit duff. Shouldn't be dropping that low.
Even very dead ones can have 12v on them, it's what they do under load that's telling;
Here's the same battery in good condition Vs when it died, with a ~1A load being applied and then removed over a period of hours - both bounce back to ~12v but you can see how the bad one doesn't have the capacity.
  • 2 weeks later...
Thanks all - bit the bullet and bought a new battery.
Now it will start if i short out the starter / solenoid but not on the key .. its almost as if theres not quite enough power to start it ... so new solenoid im guessing now ?
Thanks again for the help
will it start by bridging the battery side of the solenoid to the trigger terminal ? (white red wire)
If not then either get that one reconditioned at a good auto-electric engineers or as Ralph says put a new one on
cheers
Steve b
