uninformed Posted December 29, 2020 Share Posted December 29, 2020 Hey all, early 110 up to probably 93, part number FRC3988 - thick Late 110 probably 93 onwards, part number 571752 - thin paper Was there differences in the hub to drive flange PCD? I have early hubs but prefer the later thiner gasket. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 29, 2020 Share Posted December 29, 2020 There was a difference in some of them... The telling difference being the imperial drive flange bolts on one. However I've only ever seen a normal paper gasket for each type? Nothing 'thick'? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 29, 2020 Share Posted December 29, 2020 Thinking about it... not sure if they defender ever got imperial drive flange bolts... Quote Link to comment Share on other sites More sharing options...
western Posted December 29, 2020 Share Posted December 29, 2020 there are both types of gasket, fit doesn't make any difference to the drive member fit. FRC3988 -- https://www.brit-car.co.uk/product.php/86116/371/front_hub_drive_flange_gasket___defender_1987_to_2006_up_to_vin_ka930455 571752 -- https://www.brit-car.co.uk/product.php/80406/372/axle_drive_flange_gasket___discovery_1___defender___range_rover_classic Quote Link to comment Share on other sites More sharing options...
uninformed Posted December 29, 2020 Author Share Posted December 29, 2020 9 hours ago, western said: there are both types of gasket, fit doesn't make any difference to the drive member fit. FRC3988 -- https://www.brit-car.co.uk/product.php/86116/371/front_hub_drive_flange_gasket___defender_1987_to_2006_up_to_vin_ka930455 571752 -- https://www.brit-car.co.uk/product.php/80406/372/axle_drive_flange_gasket___discovery_1___defender___range_rover_classic From a mechanical engineering point of view, no gasket material of any kind would be best, but we have to deal with oil and sealing it. So next best thing is thinest is best. If they are the same PCD (I know both early and late 110 are M10 bolts for drive flange to hub) then I will use the thinner later type. Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 30, 2020 Share Posted December 30, 2020 By thick and thin gaskets, I think they are referring to specifications for gaskets for thick or thing hubs/drive flanges, not the thickness of the gaskets themselves. I haven’t noticed any significant variation in OeM gaskets since the SIII, the thick gaskets seeming to be the poorer quality pattern parts ( and leakier as they compress with age and allow slack in the joint). RTV sealant works fine, anyway. Quote Link to comment Share on other sites More sharing options...
western Posted December 30, 2020 Share Posted December 30, 2020 No the gaskets can be a card type material or brown paper type, the card one is noticeably thicker than the paper one. Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 30, 2020 Share Posted December 30, 2020 I understand that Ralph, but aren’t the thick ones generally pattern, not genuine? Thick gaskets are generally only useful for uneven mating surfaces. Quote Link to comment Share on other sites More sharing options...
western Posted December 30, 2020 Share Posted December 30, 2020 Some are pattern, I've used both types in the past without any leakage or problems. Quote Link to comment Share on other sites More sharing options...
hurbie Posted December 30, 2020 Share Posted December 30, 2020 i have "thick" ones from a local landrover dealer (with a hefty price tage) , so not all are patern parts Quote Link to comment Share on other sites More sharing options...
