oterpoter Posted March 18, 2022 Share Posted March 18, 2022 Hello. I am a fairly new member, living in Norway I am putting a Rover 3.5 V8 carburettor from a Rover SD1 (1984) in to a Series III 109 Exmil. I am also rebuilding the steering to power assisted steering, I have been trying to figure out what PAS pump to use. I purchased ANR2003 with ERR798 bracket and ETC6607. Alas, the low placement for this setup is impossible, the pulley collides with the chassis. Someone suggested a different pump, Hubourn Eaton 5503/8518/24 that could fit. Unfortunately I am not able to find this. I have found one on Ebay, but no reply from the seller. My guess is that someone on this forum has done this, and knows a lot more than me. I need all the help I can get, because I am now stuck. So if anyone here knows, and want to share, please do! best regards Mathias Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 18, 2022 Share Posted March 18, 2022 You'll want a later RRC pump and bracketry, mounts it high up out of the way. Quote Link to comment Share on other sites More sharing options...
oterpoter Posted March 18, 2022 Author Share Posted March 18, 2022 34 minutes ago, Bowie69 said: You'll want a later RRC pump and bracketry, mounts it high up out of the way. hello. Do you happen to know parts numbers? could this be a correct approach? https://www.advancedfactors.co.uk/power-steering-pump---defender-13634-c.asp Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 19, 2022 Share Posted March 19, 2022 Just a thought - some cars like Mercedes A-Class have small electric power steering pumps that make life easy, put them anywhere, given them 12v and away they go. Project Binky used one, it's very neat, integrated reservoir on top and everything. Made by ZF I believe. 2 Quote Link to comment Share on other sites More sharing options...
smallfry Posted March 19, 2022 Share Posted March 19, 2022 5 hours ago, FridgeFreezer said: Just a thought - some cars like Mercedes A-Class have small electric power steering pumps that make life easy, put them anywhere, given them 12v and away they go. Project Binky used one, it's very neat, integrated reservoir on top and everything. Made by ZF I believe. Astra G and Astra H diesels have them too, good thing about these pumps is that when your engine driven hydraulic pump is a bit tired, or the belt is wet, you get very little assistance at low engine speeds, whereas the electric one works all the time. They are reliable too ! 1 Quote Link to comment Share on other sites More sharing options...
oterpoter Posted March 21, 2022 Author Share Posted March 21, 2022 hello ! I will definitely check out these suggestions. I really see the benefit of having an electric pump. Better still if it fit in the opening left behind by the old steering relay box. thank you very much -mathias Quote Link to comment Share on other sites More sharing options...
oterpoter Posted March 21, 2022 Author Share Posted March 21, 2022 after some googling, i found some feedback that claims this is not too straight forward.. see below one answer. I do not want to go down a route where I purchase fairly expensive parts that I can not use. I have already done that a couple of time... "Hydraulic Electric steering. Where to begin. It's not going to be purely electric, you need a hybrid system. It's basically just an electric pump that pumps when needed, so there is also a reservoir and accumulator. The units I work with are way to expensive to justify, and work on CAN, and require a 40 amp circuit. The easiest way I would imagine would be to have a small pump and accumulator with a pressure switch that operates to tell the pump to kick on." Quote Link to comment Share on other sites More sharing options...
oterpoter Posted March 21, 2022 Author Share Posted March 21, 2022 found this on Ebay, if this still is a viable route.. https://www.ebay.com/itm/ELECTRIC-HYDRAULIC-POWER-STEERING-PUMP-SERVO-MERCEDES-W168-VANEO-W414-A-CLASS-/382924696172?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0&fbclid=IwAR3NQbud5VyNfoDqPCfLKYbYkHkJVi8RTP8V03iAyMEz0jiiYz3Jl6cD7jA Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted March 21, 2022 Share Posted March 21, 2022 It will be less trouble/cheaper just to fit the pump/bracket from a Discovery or RRC. It sits up on the left side of the engine. Plenty of Discoveries in scrap yards.... Quote Link to comment Share on other sites More sharing options...
oterpoter Posted March 22, 2022 Author Share Posted March 22, 2022 15 hours ago, TD5toV8110 said: It will be less trouble/cheaper just to fit the pump/bracket from a Discovery or RRC. I have talked to some people saying that there are many different pa's pumps out there. And the alignment of the pulley etc might not be straightforward.. I do not find this very easy, since I am new to this. If you by any chance could point me i the right direction, and even better, give me some hint of parts numbers to look for. I need a suitable pump with brackets.. I have found this schematic, but I am not able to verify if this is viable route https://www.lrworkshop.com/diagrams/land-rover-defender-engine/v8-petrol-efi/power-steering-pump_53407 Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 22, 2022 Share Posted March 22, 2022 Is it these you need? For the RRC:https://parts.jaguarlandroverclassic.com/parts/index/part/id/L2.L2G.L2G04.L2G04145/brand/land-rover/ Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 22, 2022 Share Posted March 22, 2022 Yep, as @elbekko above, that should fit. The one you link to is for the serpentine belted V8 50th anniversary, very different beast. Quote Link to comment Share on other sites More sharing options...
oterpoter Posted March 23, 2022 Author Share Posted March 23, 2022 17 hours ago, elbekko said: Is it these you need? hello. This is not the one I can use. see my initial post, where I describe what I have. It fits the motor all right, but not when the motor is in a Series III, because the placement of the motor results in the pulley hitting the chassis. I have the brackets, the ANR2003 pump, alas I need a pump that fits up and above, closer to the distributor. I know a guy in Norway that use a Hubour Eaton Pump 5503/8518/24 pump, and it is placed as mentioned above. Someone must have put a V8 in a series with PAS, and have found a solution to this.. I am at loss.. Quote Link to comment Share on other sites More sharing options...
