Footwells.
kevin50
2 hours ago, kevin50 said:
Just about ready to fit footwell floors, in parts diagram there is different screws ect, will any normal nut and bolts be OK Instead ?
I would just go with new clips and screws not expensive as if you need to remove the floors and or other stuff like gearbox tunnel and that nuts and bolts are a pain.
  • Like 1
CR is right.  Removing those floors is annoying enough with the correct fasteners, but reaching the fixings from top and bottom for those along the tunnel cover will be awful unless you fit rivnuts, and then you lose the wiggle factor for alignment.
