trickydicky Posted June 27, 2022 Share Posted June 27, 2022 can anybody give me some ideas how to get a decent fm signal on an older defender . what aerial you are using ? iv had a defender for about 15 years and iv never managed to get a good signal . Quote Link to comment Share on other sites More sharing options...
western Posted June 27, 2022 Share Posted June 27, 2022 My rubber aerial is on the roof, it gets a good signal, Make sure yours has a good clean earth to the panel it's mounted on. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted June 27, 2022 Author Share Posted June 27, 2022 yep ground is good .right or wrong i even grounded it to the bulkhead .iv tried a new aerial and a new radio but still the signal is just about ok . im wondering what aerial peaple are using ? Quote Link to comment Share on other sites More sharing options...
western Posted June 27, 2022 Share Posted June 27, 2022 My aerial the rubber one from Halfords IIRC. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted June 28, 2022 Share Posted June 28, 2022 I would say go DAB but I just have and that isn't any better in mine. So jumping on the band wagon, DAB aerial suggestions too please. Mike Quote Link to comment Share on other sites More sharing options...
Peaklander Posted June 28, 2022 Share Posted June 28, 2022 (edited) The aerial needs a good ground plane below it, that is, a large expanse of metal. This creates an image of the aerial length above and improves the 'gather' of the radio waves. This is an RF connection and it does not need to be a direct metal to metal connection. Edit. I should clarify that it’s the sheath of the cable that needs to be connected to the body metal that forms the ground plane, such as the (metal) wing. In reality I suppose this means that the base of the aerial should be in good contact with the metal work, as that is the connection to the cable sheath. Edited June 28, 2022 by Peaklander Quote Link to comment Share on other sites More sharing options...
Badger110 Posted June 28, 2022 Share Posted June 28, 2022 All good advice and to add to it, a wire coat hanger is one of the best aerials there ever was! simply put, a metal aerial with a decent ground plane works the best or if you’re willing to spend some pennies, a ‘ bee sting ‘ aerial. Ignore DAB aerials, they’re a waste of money. DAB works just as well through a standard Landy aerial with a splitter at the head unit end and 12v feed. I know this as I’ve spent a small fortune going round the houses to end up replacing the standard aerial, moving it to the front of the wing as my roof interferes with the normal position, and buying a splitter for the DAB. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted June 29, 2022 Author Share Posted June 29, 2022 i watched a video on youtube saying if you earth the chassis of the radio to a good earth this should improve the signal .iv tried lots of aerials over the years on both defenders and they've both had a rubbish signal iv got to be doing something wrong Quote Link to comment Share on other sites More sharing options...
