Simon Smith Posted December 27, 2022 Share Posted December 27, 2022 (edited) Two years ago I replaced the head gasket and the bolts, the head had a light skim and all was well for a while. A few months later and it developed a slight oil leak at the front of the head, now the leak is getting worse and I think I need to do the job again. I seem to remember a discussion about the different quality of various gaskets and that some were prone to leaking in this area. Which gasket is considered the best available by everyone? I really don't want to keep having to do this. Edited December 27, 2022 by Simon Smith Quote Link to comment Share on other sites More sharing options...
monkie Posted December 27, 2022 Share Posted December 27, 2022 I use the Elring head gasket which can be found here. Note that different thicknesses are available depending upon the piston protrusion relative to the deck of the block. Quote Link to comment Share on other sites More sharing options...
steve b Posted December 27, 2022 Share Posted December 27, 2022 Elring for me too. Steve Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted December 27, 2022 Author Share Posted December 27, 2022 Fairly certain that's what we used. Came from Turner, they're just down the road. Quote Link to comment Share on other sites More sharing options...
western Posted December 27, 2022 Share Posted December 27, 2022 Elring everytime for my 200tdi, the oil leak maybe from the semi circle seal at front of cylinder head & rocker cover Quote Link to comment Share on other sites More sharing options...
miketomcat Posted December 27, 2022 Share Posted December 27, 2022 Elring for me too. However the current gasket isn't because I was skint and in a hurry (having done three head gaskets on the same engine this year). Mike Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted December 27, 2022 Author Share Posted December 27, 2022 1 hour ago, western said: Elring everytime for my 200tdi, the oil leak maybe from the semi circle seal at front of cylinder head & rocker cover I've done the rocker cover seals. You can see oil seeping out of the cylinder head joint with the engine running, and I think it started to "chuff" quietly today too. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted December 28, 2022 Share Posted December 28, 2022 Daft question but did you get all the oil/water out of the bolt holes before the head was fitted. It's easy to forget and it only takes a small amount to hydraulic the bolt, then it torque's correctly but is in fact loose. Mike 1 Quote Link to comment Share on other sites More sharing options...
