hurbie Posted March 23, 2023 Share Posted March 23, 2023 hello all , does anybody know the size of the thickest piece on this mandrell (used for setting up the LT230 transfercase . the thin part is "just" a piece of gearbox output shaft . or is somebody good at 'gestimating' the size's from the picture below ? picture is from : https://www.dingocroft.co.uk/acatalog/Input-Gear-Turning-Mandrel-LRT_41_005.html Quote Link to comment Share on other sites More sharing options...
western Posted March 23, 2023 Share Posted March 23, 2023 Email Dingocroft & ask Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 23, 2023 Share Posted March 23, 2023 Surely if it's just for rotating the input gear then the thick bit is just to grip by hand. If so I would guess around 50mm. Mike Quote Link to comment Share on other sites More sharing options...
pat_pending Posted March 23, 2023 Share Posted March 23, 2023 4 minutes ago, miketomcat said: Surely if it's just for rotating the input gear then the thick bit is just to grip by hand. If so I would guess around 50mm. Mike You wrap a cord around the end and then pull it with a spring balance to check the bearing preload. The diameter will make a difference to the result. It's many years since I worked for a main dealers and we rebuilt these regularly, but we just did them by feel in the end, although that's probably not helpful to the op. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted March 24, 2023 Share Posted March 24, 2023 Years ago Ashcrofts were doing gearbox build demonstrations at Billing. I was about to rebuild my own box so spent a while talking to the chap and he took me through LT230 assembly. This included giving me the opportunity to feel what the correct preload felt like. Free to turn, but with a little resistance is as good as I can describe it. That was how he did it, with experienced hands and eyes. 1 Quote Link to comment Share on other sites More sharing options...
hurbie Posted March 26, 2023 Author Share Posted March 26, 2023 send a e-mail to dingocroft , lets see if there willing to share the secret 😉 in the meantime i printed the foto of the part , measured from the foto and compered with actual measurments, and calculated it's real world size , this seems to be around 55mm diameter . Quote Link to comment Share on other sites More sharing options...
ashtrans Posted March 27, 2023 Share Posted March 27, 2023 or use : https://ashcroft-transmissions.co.uk/product/ftc5090/ 1 Quote Link to comment Share on other sites More sharing options...
hurbie Posted March 27, 2023 Author Share Posted March 27, 2023 8 minutes ago, ashtrans said: or use : https://ashcroft-transmissions.co.uk/product/ftc5090/ is that the same size as the Landrover tool ? Quote Link to comment Share on other sites More sharing options...
ashtrans Posted March 28, 2023 Share Posted March 28, 2023 17 hours ago, hurbie said: is that the same size as the Landrover tool ? I have no idea but it looks like this tool is only used to turn the input gear, FTC5090 will do this too, Quote Link to comment Share on other sites More sharing options...
hurbie Posted March 28, 2023 Author Share Posted March 28, 2023 5 hours ago, ashtrans said: I have no idea but it looks like this tool is only used to turn the input gear, FTC5090 will do this too, no , see below .... On 3/23/2023 at 10:31 PM, pat_pending said: You wrap a cord around the end and then pull it with a spring balance to check the bearing preload. The diameter will make a difference to the result. It's many years since I worked for a main dealers and we rebuilt these regularly, but we just did them by feel in the end, although that's probably not helpful to the op. Quote Link to comment Share on other sites More sharing options...
pat_pending Posted March 28, 2023 Share Posted March 28, 2023 Thinking about this, as we used to do so many and had one set of special tools, that never got put back or were used for other purposes, I made my own from a scrap LT77 mainshaft (we had lots of them). It's probably 30 years ago but I "may" still have it. I remember welding something on the end for the cord to go, I'd have chosen something the right size I'm sure. I say "may" as we just got used to setting them by feel in the end, although being a hoarder I doubt I'd have chucked it. I'll have look in the w/shop here tomorrow, I know it's not at work. Quote Link to comment Share on other sites More sharing options...
hurbie Posted March 29, 2023 Author Share Posted March 29, 2023 21 hours ago, pat_pending said: I'll have look in the w/shop here tomorrow, I know it's not at work. thanks already for the effort ! Quote Link to comment Share on other sites More sharing options...
pat_pending Posted April 1, 2023 Share Posted April 1, 2023 On 3/29/2023 at 7:42 PM, hurbie said: thanks already for the effort ! I had a look but can't find it. Sorry for the delay, I'm recovering from Covid and everything's an effort. Quote Link to comment Share on other sites More sharing options...
hurbie Posted April 1, 2023 Author Share Posted April 1, 2023 1 minute ago, pat_pending said: I had a look but can't find it. Sorry for the delay, I'm recovering from Covid and everything's an effort. no problem , thanks for looking . and good luck recovering ! Quote Link to comment Share on other sites More sharing options...
