Debender Posted November 3, 2023 Share Posted November 3, 2023 Hi, iv been driving my 200tdi 90 around recently and noticed a new noise coming form around the gearbox it sound like what I would imagine a loose bearing would sound like. metal on metal grinding. It comes and goes but only when driving (never when idling). Any advice would be greatly appreciate Quote Link to comment Share on other sites More sharing options...
western Posted November 3, 2023 Share Posted November 3, 2023 Examine the front propshaft universal joints for excess wear & lack of lubrication 1 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted November 3, 2023 Share Posted November 3, 2023 I agree with Ralph that they are likely the culprit. Other possibilities are a faulty starter motor, flywheel ring gear or clutch release bearing. Quote Link to comment Share on other sites More sharing options...
Debender Posted November 3, 2023 Author Share Posted November 3, 2023 3 hours ago, Snagger said: Other possibilities are a faulty starter motor, flywheel ring gear or clutch release bearing. Hi thanks for the advice, would the faulty starter and clutch bearing not also make a noise when idling, and not supper experience so any tips for checking the front prop shaft universal joint thanks Quote Link to comment Share on other sites More sharing options...
fmmv Posted November 3, 2023 Share Posted November 3, 2023 What they said. Or even the handbrake binding on. Quote Link to comment Share on other sites More sharing options...
Snagger Posted November 4, 2023 Share Posted November 4, 2023 The clutch release bearing would likely change in noise considerably when pushing the clutch pedal down or releasing it. A bad starter or ring gear should vary in tone with engine rpm rather than road speed. Something in the gear box is going to be subject to road speed and gear selection. A prop shaft issue (usually the UJs) or diff problem will be subject to road speed and torque but not gear or engine rpm. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted November 4, 2023 Share Posted November 4, 2023 Loose mud shield on the output flanges of the transfer box? 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted November 4, 2023 Share Posted November 4, 2023 1 minute ago, vulcan bomber said: Loose mud shield on the output flanges of the transfer box? Or even just proud enough to catch on the prop flange bolts… Quote Link to comment Share on other sites More sharing options...
steve b Posted November 4, 2023 Share Posted November 4, 2023 Check the front wheel bearings too - if slack enough the disc will scrape the dirt guard. Front prop is no. 1 suspect , best checked by removing it to get a proper feel of the UJ bearings Steve Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted November 4, 2023 Share Posted November 4, 2023 1 hour ago, steve b said: Check the front wheel bearings too - if slack enough the disc will scrape the dirt guard. Is possible, but if you can feel it in the brake pedal too. The tumbling disk will spread the brake pads and you will have to allign them with the pedal bevore the brake works. Is there a stone between brake guard and disk? Quote Link to comment Share on other sites More sharing options...
Dave9252 Posted November 4, 2023 Share Posted November 4, 2023 If its behind the dash, then check your speedo cable. If its worn itself loose then it'll give you a spinning/ grinding noise. Quote Link to comment Share on other sites More sharing options...
