o_teunico Posted Thursday at 10:01 PM Share Posted Thursday at 10:01 PM Hi all! My poor 88" needs new shock absorbers. It's already on parabolics. Really can't decide what to do...not taking in account needed hardware modifications and beeing in the same budget...should I go for good quality single shock or better take the "blue kwality" cheapo option but with twin shock per wheel? TIA Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted Thursday at 10:17 PM Share Posted Thursday at 10:17 PM Twin shocks on a Series? Do you have custom mounts? You say parabolic suspension. Is it setup for flex or hauling? Have you gained any travel? What do you plan to use the vehicle for? I had custom upper mounts and some other mods at the front on my 88. I spoke with Llama 4x4 (David) and he set me up with some Rough Country shocks, which worked really well. But you’ll have to speak to him and see if he has anything suitable for your setup. Quote Link to comment Share on other sites More sharing options...
o_teunico Posted Thursday at 11:08 PM Author Share Posted Thursday at 11:08 PM (edited) It's a Santana, parabolics came fitted from factory back in 1983. Used for light off road. After a rotten chassis rebuild, I lost front anti roll bar (no mounts in new chassis), but I maintain the bar mount in axle, so I thought about using that mount for a second shock. Same in rear, no mount for bar in chassis but spare mount in axle. Edited Thursday at 11:09 PM by o_teunico Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted Friday at 07:10 AM Share Posted Friday at 07:10 AM Honestly the only reason people used twin shocks in the past was because older shock tech was just not as good as it is today. Single will be more than you need unless you suddenly need to go and do Baja. 1 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted Friday at 08:06 AM Share Posted Friday at 08:06 AM Two crappy shocks does not equal one good shock though - it just equals an even worse ride than a single crappy shock. 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted Friday at 08:25 AM Share Posted Friday at 08:25 AM Agreed, just fit a decent single and be done with it. 1 Quote Link to comment Share on other sites More sharing options...
o_teunico Posted Friday at 08:59 AM Author Share Posted Friday at 08:59 AM Ok, no Baja needed, will go for single quality setup. I may use that front bar mount clocked in axle so the new shock will have the bushing in the "correct" position for flex. I have a spare set from the front axle of a Santana six for the rear axle. Quote Link to comment Share on other sites More sharing options...
Arjan Posted Friday at 08:06 PM Share Posted Friday at 08:06 PM I have TIC Console Parabolics under the 88" and KONI shocks. Works very, very well. 1 Quote Link to comment Share on other sites More sharing options...
Jon White Posted Friday at 09:42 PM Share Posted Friday at 09:42 PM I recently fitted britpart cellular foam shocks to my truck, replacing my work out pro-comps. I’m very happy indeed with them and would recommend them. See the post a few threads down regarding them. 1 Quote Link to comment Share on other sites More sharing options...
o_teunico Posted Friday at 11:53 PM Author Share Posted Friday at 11:53 PM Interesting to see that Britpart Foam are about same dimensions that standard rear shocks on Disco 2. Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted Saturday at 06:17 AM Share Posted Saturday at 06:17 AM I also have the Britpart Celluar Dynamic shocks. Although not on a leader. For the money I think they are good. For me they replaced some Pro Comps I had (can’t recall which variant). The park Comps were lovely and soft, esp on rough ground. But gave the vehicle a lot of roll on road. The Celluar Dynamics are much firmer. They still flex well off road, but driving over a stumble field isn’t as compliant. On road the ride is firmer but quite acceptable. They aren’t uncomfortable, just firmer. But they have transformed the handling massively reducing lean. My brother and Uncle also have the Celluar Dynamic shocks and all comment how good they are for towing. For the money I’d say they are a very good shock. But no idea what lengths are available for a Series. Quote Link to comment Share on other sites More sharing options...
