Green200tdi Posted August 16 Share Posted August 16 Is it possible to weld a hole in the roof of my 1986 110? there was a shaped bit of wood in the rear of the landy possibly holding up the rear head lining, when I removed it it was screwed thu the roof from the outside so want to make it water tight. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted August 17 Share Posted August 17 You can weld it with mapp torch and aluminium brazing rods, plenty you tube videos on how to do it, you could also use chemical metal such as plastic padding products to seal it, flatten back and touch up. The latter being the easiest solution, if your going to heat weld it you will need a bigger area of clean material and thus a bigger cover up job afterwards Regards Stephen Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted August 17 Share Posted August 17 Why not riveting the holes? Quote Link to comment Share on other sites More sharing options...
simonpelly Posted August 17 Share Posted August 17 Riveting as above sounds like a good solution. For some perhaps larger diameter holes, we resorted to some plastic plugs. https://pellylandroverdefender.blogspot.com/p/roof-and-headlining.html Quote Link to comment Share on other sites More sharing options...
Northwards Posted August 17 Share Posted August 17 Interesting to see those pics Simon. My car was an ‘airfield ops’ vehicle, with aerial holes and power for lights etc. They didn’t make too many holes, but the ‘ugly mastic spread’ is almost a carbon copy. I’ve never touched it, but I think the time is approaching when I’ll need to look at this. What are those plastic plugs called? What’s their purpose? Any kind of link? Would appreciate that. I had thought of getting some old panel aluminium, cutting a suitable piece, feathering the edge, and then bonding into place where I have a small cluster of holes, but perhaps those plugs might be a solution where there’s an isolated one. Quote Link to comment Share on other sites More sharing options...
simonpelly Posted August 17 Share Posted August 17 @Northwards - Believe these were the items - https://www.toolstation.com/overflow-stopper/p51215 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted August 17 Author Share Posted August 17 Brilliant, I just want the roof to look original no leaks as it’s the only hole, repair it then paint it white something to think about for future job, thank you all love the photos.👍😊 Quote Link to comment Share on other sites More sharing options...
Northwards Posted August 17 Share Posted August 17 4 hours ago, simonpelly said: @Northwards - Believe these were the items - https://www.toolstation.com/overflow-stopper/p51215 Thanks for that - obvious enough when you see them. 👍 Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted August 18 Share Posted August 18 If you want to have an original look, glue an aluminium sheet from the inside and apply filler from the outside. Quote Link to comment Share on other sites More sharing options...
Jon White Posted August 20 Share Posted August 20 Yes I have welded up loads of holes in mine. I just migged them up and then sanded them off flat. Once prepped and painted it looks factory 👍🏻 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted August 21 Author Share Posted August 21 On 8/20/2024 at 4:10 PM, Jon White said: Yes I have welded up loads of holes in mine. I just migged them up and then sanded them off flat. Once prepped and painted it looks factory 👍🏻 👍😊 Quote Link to comment Share on other sites More sharing options...
smallfry Posted August 22 Share Posted August 22 Or try Luminweld ? Quote Link to comment Share on other sites More sharing options...
