Grant Posted August 15, 2007 Share Posted August 15, 2007 Has anyone had any problems with the Rear stop/tail lights from Paddocks made by Wipac?? They are the ones in the series section RTC5523 is the product code. I bought a pair recently and the plastic is so soft the bulbs kept popping put I rang Paddocks and they said they would get onto Wipac..... Still nothing back. I ordered a new set and had the same thing again..... i know the bulbs go in a certain way. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted August 15, 2007 Share Posted August 15, 2007 My mate has had the same problem..... Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted August 15, 2007 Share Posted August 15, 2007 Is that the NAS style lights? Quote Link to comment Share on other sites More sharing options...
Grant Posted August 15, 2007 Author Share Posted August 15, 2007 Dunno what NAS style is.............. So annoying though, looking at the plastic it seems really cheap. Any other folk supply these. Quote Link to comment Share on other sites More sharing options...
western Posted August 15, 2007 Share Posted August 15, 2007 NAS style are the same size as the late Td5 & current 07 90/110 rear fog & reverse lights. Quote Link to comment Share on other sites More sharing options...
BLACK CAB Posted August 15, 2007 Share Posted August 15, 2007 I have had the same problem with Wipac, the bulb holder material is to soft + the internal dia is oversize. The bulb dose not sit in the holder square and allows one of the bayonet pins to jump out, the remaining one then cuts up the side of the holder. I had 2 replacements from Padocks.........got fed-up and brought LEP ones from Bear Mach. Also have you noticed that the drain holes are at the 3/9 o'clock position! Rod Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted August 15, 2007 Share Posted August 15, 2007 Got a full set of NAS Wipac from Paddock, all OK, but the rear reds need a bit of hole filing to get them to fit flush to the lines of the body (they are large diameter and stick out too much unless the centre of the hole is relocated). Fronts need to have the ring that accepts the NAS light chamferred to accept the front light surround, but once in, they are good fit. Seem to be well made. Quote Link to comment Share on other sites More sharing options...
Grant Posted August 15, 2007 Author Share Posted August 15, 2007 So the lights from Bear Mach are they and good.................Not buying from paddocks both sets i have had have been rubbish. How do the Bear Mach compare in price? Quote Link to comment Share on other sites More sharing options...
BLACK CAB Posted August 15, 2007 Share Posted August 15, 2007 The Bear Mach supplied LEP's are slightly more expensive, but work perfectly. I believe LEP was a original supplier for LR. Rod Quote Link to comment Share on other sites More sharing options...
Grant Posted August 15, 2007 Author Share Posted August 15, 2007 Cheers Rod Do they have an on line shop? Just googled and the site I looked at was odd Quote Link to comment Share on other sites More sharing options...
BLACK CAB Posted August 15, 2007 Share Posted August 15, 2007 No.......Not as such, email your enquiry or phone them. I think they have PDF parts lists that you can find their part references in. Generally fairly quick in getting back with price & availability. Swindon - 01793 513744 - swindon@bearmach.com Maidstone - 01622 717525 - seshop@bearmach.com Rod Quote Link to comment Share on other sites More sharing options...
Stonehead1 Posted August 16, 2007 Share Posted August 16, 2007 I've had to replace the rear lights a couple of times (women drivers backing MPVs into the Defender - guess who came off worst?). I just go down to my local agricultural merchant and buy trailer lights for £1.99 each, complete (both tail lights and indicators). They fit my 90H 110 exactly and are very well made - don't know who makes them but they're good value. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 16, 2007 Share Posted August 16, 2007 Yes, I've got Wipac lights from paddocks on the 109 and they're cack - half of the threaded bits for the lens screws split apart and that was from the packet, undoing the lens to put the bulb in! It's another example of paddocks selling stuff that's too cheap - charge me 50p extra per light and make them properly FFS Quote Link to comment Share on other sites More sharing options...
LR90 Posted November 6, 2007 Share Posted November 6, 2007 Well this has bitten me too. Replaced OSF indicator and side light with the paddocks units. Indicator seems ok but the sidelight only works until I hit a bump and then its cover off to refit the bulb. Swapping bulbs and attempting to put a collar on the bulb to steady it haven't helped So, off to Bearmach or does anyone know if Brookies stock a better made unit? Quote Link to comment Share on other sites More sharing options...
