300TDi engine.
Les Henson
My guess would be that the housing would fit with a bit of hole adjustment but the flywheel would need more major surgery. You should be able to get an old flywheel from someone who has done an auto conversion though.
Si
I have one, but it has the flywheel and housing missing. I have a TD flywheel housing and flywheel - anyone know if they will fit and still attach to an LT77 Box?
Thanks.
Les.
Speaking from experience both flywheel and housing fit straight on. Ask user rock_on_skeeter on here, its the exact setup he has in his 90
The 300 flywheel housing has a cut out for a plate that retains the crank oil seal, whereas the TD/200tdi uses the flywheel housing itself. If you use the TD housing then you can butcher it to suit the plate, or leave it and use a TD style crank seal. The 300 one is better IMHO
