Tonk Posted November 4, 2005 Share Posted November 4, 2005 been workin on a disced handbrake conversion for my truck, as usual Jon White is working with me haven't quite finished yet but bits so far stripped off handbrake drum and back plate and bolted on caliper mounting bracket disc is mounted to output flange, output flange has been machined down to suit this is the caliper, slightly modified. have extended the arm which locates the cable coming in and theres also an air connection been added which will adjust the caliper when the pads wear a bit just need to pop it all on the back of the gearbox now and connect on the 90 handbrake and cable, should have that finished this afternoon so i can test it out Quote Link to comment Share on other sites More sharing options...
02GF74 Posted November 4, 2005 Share Posted November 4, 2005 It warms the cockles of my heart to see novel applications of copper tubing That look like a car type tyre valve on the end - so you pump air into that tube - please explain how it works. Are you able to weigh the parts so see if it is lighter than the drum hand brake? ... and neat job BTW. Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 4, 2005 Author Share Posted November 4, 2005 it is copper brake pipe the idea is that when the caliper needs adjusting all i have to do is plug an air line on the connector and pump the piston out with air, this will rachet the piston out and adjust it, there obviously no valve in the air connection cos it doesn't need to stay pressurized. errrrr weigh the parts, hmmmmmmm dont know if i can be bothered, its goin on if its heavier anyway Quote Link to comment Share on other sites More sharing options...
Jon White Posted November 4, 2005 Share Posted November 4, 2005 Does it really matter how much it weighs??? I mean - who cares??? The series handbrake is sooooo carp I couldnt care if it weighed 10 times more so long as it actually works! Air line fitting is to allow the caliper to be adjusted up as the pads wear as theres no hydraulic connection to it. Jon Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 4, 2005 Author Share Posted November 4, 2005 i think there wont be alot of difference in the weight one way or another, dont think it will really make that much difference to the weight of my truck anyway As Jon says, it will be nice to have a handbrake u can trust to work and wont wear out as quickly or just sieze up after its been left for a week after drivin in the mud Quote Link to comment Share on other sites More sharing options...
Mark Posted November 4, 2005 Share Posted November 4, 2005 What's the calliper from? Mark Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 5, 2005 Share Posted November 5, 2005 I have the added benifit of seeing it in the flesh, actaully I have the second one in my boot (all bids PM please don't want Jon to know I am selling it, I'll just say it was stolen one night ).... And its 1.) nicely made 2.) simple 3.) WTF does the weight have to do with it ? Frankly it (disc claiper and plate) prob weight less than the drum shoes mud and backplate, but I am at a loss as to why the weight matters ?...its lathe made so in balance (well enough for a piggin LR), confused and puzzled don't even come into it.. I'd fit it in a nano second to the 90, if it fitted. Tonk rightly deserves praise for simple well made and clever thought driven improvements, ... rather than some weird "Wots its weight" irrelevent Q ?????, sorry but as someone who tries to use me brain and do innovative things I if I were Tonk might just be a bit P O with this comment ?...as a Mod maybe he has to behave more, than me ?? Nige Quote Link to comment Share on other sites More sharing options...
02GF74 Posted November 6, 2005 Share Posted November 6, 2005 3.) WTF does the weight have to do with it ?Frankly it (disc claiper and plate) prob weight less than the drum shoes mud and backplate, but I am at a loss as to why the weight matters ?...its lathe made so in balance (well enough for a piggin LR), confused and puzzled don't even come into it.. rather than some weird "Wots its weight" irrelevent Q ?????, sorry but as someone who tries to use me brain and do innovative things I if I were Tonk might just be a bit P O with this comment ?...as a Mod maybe he has to behave more, than me ?? Nige I cast out a fat juicy worm and wait for someone to bite...... did you not see the in the original post? ... and why is asking a question comparing their wight to drum, relevant or otherwise, interpreted as an attack on Tonk's design and fabrication abilities?!?!?!?!. Confused and puzzled here as well. Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 7, 2005 Author Share Posted November 7, 2005 HFH, is that a compliment in there somewhere? fitted it all up at the weekend, all bolted up as expected, adjusts up easy with the air line connected and works a treat. quick pic of it all fitted, hard to see much cos the caliper is mounted between the t/box and chassis so it cant get knocked about Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 7, 2005 Share Posted November 7, 2005 Sorry ! Nige PS Have you thought that the sticker on the prop adds extra weight - you could counter the effects of the disc weight by removing it Nige Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 7, 2005 Author Share Posted November 7, 2005 i didn't want to take the sticker off, 2 reasons, they might have skimped on paint and not painted under there, resulting in rust and secondly, i didn't want to throw the balance of the prop out, i've got the mud covering just right now Quote Link to comment Share on other sites More sharing options...
series3_mad Posted November 7, 2005 Share Posted November 7, 2005 tonk, did u get it as a kit if so how much or did u make it? Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 7, 2005 Author Share Posted November 7, 2005 u know me i made it Quote Link to comment Share on other sites More sharing options...
series3_mad Posted November 7, 2005 Share Posted November 7, 2005 cool, did it take long to make Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 7, 2005 Author Share Posted November 7, 2005 about 3 or 4 hours after initial workings out, easy enough, then just fitting it, changed output seal whilst i was there and make brackets etc for the h/brake lever Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted November 7, 2005 Share Posted November 7, 2005 Nige you are ssoooooooooooooooooooo funny! Tonk caring to behave himself wether he is a mod or not????????????????? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 7, 2005 Share Posted November 7, 2005 he tells me he's "reformed" somefink about poachers and gamekeepers ? Nige Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted November 7, 2005 Share Posted November 7, 2005 yeah right! nudge nudge say no more! Quote Link to comment Share on other sites More sharing options...
simonr Posted November 25, 2005 Share Posted November 25, 2005 Competition! Looks good! I presume you machined off the ring of six bolts which normally holds the drum in place? I like the idea of putting the caliper at the 3 o'clock position - my biggest issue with a series version was how close the disk sits to the back of the gearbox. I have a fully mechanical caliper - of a much simpler design to the defender model (and a fraction of the price!) which would be well suited to this orientation. I got the caliper originally for a rear disk conversion for quads. With this arrangement, a laser cut back plate with a total of three folds to mount the caliper and cable would be feasible. As you can see it is not small. The first version of the defender disk handbrake used a very similar caliper to yours: Which came off a Volvo 740GLE (although someone has said it's off something else?). The reason I changed it was the self adjust mechanism filled up with mud and corroded to the point of being destined for the bin! Your caliper looks in much better condition to start with - so may have better seals and last much longer. Mine did give sterling service for 2 years though. What arrangement have you used for the cable? Have you replaced the original lever with a Defender or RR type, or adapted the original mechanical linkage to accept a cable? Si Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 25, 2005 Author Share Posted November 25, 2005 Caliper is rover 800 rear, monted on a caliper plate which is flat, this puts the caliper between the t/box and chassis so it cant get damaged. disc is flat and mounted to back of out put flange which has had its outer flange machined off with the six bol;t holes in which hold the drum on. cable and lever is standard 90 stuff. Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 25, 2005 Author Share Posted November 25, 2005 Competition! Si not meant as competition, if u had a kit ready then i probably would've just bought one, i was just too impatient to wait Quote Link to comment Share on other sites More sharing options...
simonr Posted November 25, 2005 Share Posted November 25, 2005 not meant as competition, if u had a kit ready then i probably would've just bought one, i was just too impatient to wait Making your own is more satisfying though! It's just difficult if you don't have the facilities to actually do it, which is where a bolt-on kit comes in. If you are using a defender lever, did you just add a big spreader plate inside the seat box or come up with a way of mounting it off the chassis? Si Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 25, 2005 Author Share Posted November 25, 2005 i just mounted it on a plate on the front of the seatbox, well sturdy. i had the disc laser profiled cos i didn't have any 10mm plate, but machined the mounting plate up on the lathe and mill, cheaper that way until i know it all works. laser profiling is the way to go though imo, unfortuneately i dont have one of them Quote Link to comment Share on other sites More sharing options...
simonr Posted November 25, 2005 Share Posted November 25, 2005 i just mounted it on a plate on the front of the seatbox, well sturdy.i had the disc laser profiled cos i didn't have any 10mm plate, but machined the mounting plate up on the lathe and mill, cheaper that way until i know it all works. laser profiling is the way to go though imo, unfortuneately i dont have one of them I'm very fond of laser cutting! It's good value for production runs, but expensive for prototyping. At the moment, I'm building a CNC plasma table (like a big XY plotter) which should make it possible to produce accurate prototypes - just with a bit more grinding & finishing required. Should be a lot less effort than milling shapes - although I'm starting to wonder if the huge amount of milling required to make the bearing blocks & stepper mounts for the lead-screws is worth it! Suppose I could sub it out to a CNC shop! Si Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 28, 2005 Author Share Posted November 28, 2005 all my development are done on my cad system, cnc punch a template/jig so i can eye everything up and make adjustments etc, then if i know everything works i have the cad drg for the profilers Quote Link to comment Share on other sites More sharing options...
