white90 Posted November 8, 2005 Share Posted November 8, 2005 look at pic near bottom Nige this may suit your application Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 8, 2005 Author Share Posted November 8, 2005 Tony, Can't see pics as I am not registered, and I don't bother to register where I will prob never go back to ? Thread seems to be about wider arches ?....these I don't need (or like - they look kin orrible), but can't see anything re gluing ? Or am I missing your reply completely ? Possibly after horrible 15 hour day Nige Quote Link to comment Share on other sites More sharing options...
white90 Posted November 8, 2005 Share Posted November 8, 2005 Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 8, 2005 Author Share Posted November 8, 2005 JEEEEEEEEEEEEEEEZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZz SPACER ALERT ! Look at the hubs and how inset they are.... My problem is the tyres fit inside the arch (just) its that the fixings have be ground away and I need to glue the little thats left to the little thats left of the ali arch Nige Quote Link to comment Share on other sites More sharing options...
LR90 Posted November 8, 2005 Share Posted November 8, 2005 yes, not for me either. No point chopping the tub about for those, they would never fit inside the arches. Quote Link to comment Share on other sites More sharing options...
white90 Posted November 8, 2005 Share Posted November 8, 2005 Trev the tub has not been chopped just a strip of ali added to standard arch extendeding the arch out. they'd get ripped off first time out round these parts but they look ok to me. Quote Link to comment Share on other sites More sharing options...
MarkieB Posted November 9, 2005 Share Posted November 9, 2005 I hope I've understood correctly; so you've not got the 'lip' that juts into the wheelspace around the wheelarch. One option would be to [ali] rivet a new lip on [you could weld for neatness although involves a bit of time tidying up], then attatch the eyebrow to the new lip with the plastic rivets as normal? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 9, 2005 Author Share Posted November 9, 2005 OK, I try to explain better. TUB. There is a lip, folded inwards the radius of the eyebrow. Or not in my case now, this lip has been removed sround the 11.00 - 3.00 position, there is now ONLY the lip from the bottom of the tub upwards to tghe 11.00 - 3.00 positions, and nothing in between. The panel has then bben "Flared" outwards, this allows the trye access and clearanbce. EYEBROW. There is a rubber lip which runs around the back of the eyebrow, this normally is clipped to the ali flange on the tub. Again the 11.00 - 3.00 part of this return on the eyebrow has been removed. As such the arches are back on the LR. The bottom to 11.00 and botom to 3.00 stips met up and are clipped into place. The 11.00 - 3.00 area is "hanging in the wind" and as such needs glueing on. Hope this is cleaer ? I don't wnat to extend or add wider arches, the tyre does now clear on is route upwards, the returns from the tub abd the body were hitting the sidewall, so had to go. Nige Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 9, 2005 Share Posted November 9, 2005 Nige, why dont u just lob the wing off upto where u've put the raised boxes and then just fit new arches and fix through the flange as normal, job done. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 9, 2005 Author Share Posted November 9, 2005 Plan A seems far simpler, just stick them on with something ! and with the new High Tech glues about, job done. Nige Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 9, 2005 Share Posted November 9, 2005 bet you're glad u thought the whole thing through before doing any cutting Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 9, 2005 Author Share Posted November 9, 2005 Nige Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 9, 2005 Share Posted November 9, 2005 alternately restict articulation, put standard wheel boxes back in then its easy Quote Link to comment Share on other sites More sharing options...
Jon White Posted November 9, 2005 Share Posted November 9, 2005 Wheels with 1/2" less offset??? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 9, 2005 Author Share Posted November 9, 2005 handbrake disc with your head embedded in it ? Nige Quote Link to comment Share on other sites More sharing options...
