Advice needed on sticking things on !
Hybrid_From_Hell
The arches on the back of the 90 have been er..."Trimmed" a lot !.
I no longer have the flange that runs around the wheel arch lip (actaully quite of lot of this has ben cut off too :huh: ), so the arch is now only properly "Clipped" on the 2 sides, the top is, weell, theres nothing really there, the arch (ali) and the arch (rubber) both trimmed hard back....
My plan is too glue these on, and then use the few clips there are as well....
What to use is the Question ?
I have thought of either the stuff they use for putting in windscreens on cars, oe maybe silicone sealer ?...Jon W mentioned something called "Tigergrip" but can't find that ?
In todays wonderful Hi tech world what a good "Glue" / "Stuff" to glue these on with, basically I expect whatever it is to "be a one off" and I do not expect to have to remove them again, in fact if I do it will be due to damage, so I would expect the arch to be either KIA or killed removbing it !!
Ideas of whats out there then ?
Nige :ph34r:
Nige, I'd go for a contact adhesive.
Did anyone see the Scrapheap challenge when about an hour to go the 'expert' used contact adhesive to stick a truck inner tube to their ice machine. Half way round applying it inner tube goes POP!!
:huh::huh::huh:
Classic- the looks on the other members of the team.
Steve :)
